Old 13th January 2010, 11:11 PM   #1
bill26 is offline bill26  Canada
Default new drivers for old actives
after a month here & on other sites,i have given up trying to obtain 'original' replacement woofers for my meridian m-30's.these were custom 4 ohm b200 kef drivers,over 20 years old.after much harassing of a number of people, i have acquired 2 audax hm130 co's.they are 6 ohm,though. i was told there would be a difference in output of 1.5db.i was also told that because the meridians use an active crossover that this can be compensated for.i am a luddite.is this correct? should i cancel the order?
Old 14th January 2010, 03:48 AM   #2
Shaun is offline Shaun  South Africa
Shaun's Avatar
You could compensate for the response of the new drivers in the active crossover, but then you'd need the schematic. And the ability to do acoustic measurement and loudspeaker system simulation.
BTW, are these analogue or DSP-based crossovers? If it is DSP, then it would be close to impossible to modify them without some help from Meridian.
Why not suck it and see?
Also, BTW, have you tried to get some assistance from Meridian?
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 14th January 2010, 09:37 AM   #3
Francec is offline Francec  Australia
Banned
Sorry Bill, I would try to help but I can't make out what language you are using.
Old 14th January 2010, 10:46 AM   #4
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Originally Posted by bill26 View Post
After a month here & on other sites, I have given up trying to obtain 'original' replacement woofers for my Meridian m-30's.
These were custom 4 ohm, b200 kef drivers, over 20 years old.
After much harassing of a number of people, I have acquired 2 Audax hm130 co's. They are 6 ohm, though.
I was told there would be a difference in output of 1.5db.
I was also told that because the Meridians use an active crossover, this can be compensated for.
I am a luddite.
Is this correct? Should I cancel the order?
It was in Canadian.
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 14th January 2010, 11:30 AM   #5
yes. the speakers are analogue-1986,actually.meridian dont wanna know.they sent me to aralex,who sent me to solen... i wound up talking to a gent in denmark who helped me out the most, so i got the drivers from him.eventually i will get the old ones refurbished-unless i like these audax.
JBL comp drivers, Dayton Reference Sub drivers for auction NO RESERVE pkpickard Swap Meet 1 21st January 2009 03:19 AM
FS: x25 Vifa 5" Drivers + x2 Diamond Audio 5.6 Hex Eton Drivers omarmipi Swap Meet 0 19th November 2007 04:21 AM
FS: Line Array Drivers - 84 drivers only $200.00! Magnetar Swap Meet 1 23rd August 2007 04:34 PM
Open-Baffle dipoles...a heresy to pair PA drivers w/ home drivers? thadman Multi-Way 7 11th November 2006 09:11 PM
FS: horn subs, drivers, 'regular' subwoofer drivers John Sheerin Swap Meet 0 1st August 2004 11:33 PM
Page generated in 0.08243 seconds (73.28% PHP - 26.72% MySQL) with 10 queries
