Old 9th January 2010, 09:40 PM   #1
soulray is offline soulray  Shetland Islands
Exclamation A soulful solution?
Greetings all. Been advised to post my introductions post here to glean the opinions of some of you vastly more experienced folk. Here goes:
On the audio front, I had the crazy notion of putting together a compact, i.e. portable sound system, for using at "Soul Nights", (smallish, specialist soul music evenings), where despite the shared love of rare music from a bygone era, this precious (and expensive!) vinyl, gets played through truly God-awful sound systems. So it sounds comprehensively worse than when played at home!
Will need to be able to create decent, danceable sound levels for between 50-100 people, but huge amounts of bass not really required. Looking for good, clear vocal/midrange and accuracy rather than quantity in the bass department! In other words, I'm after the sound of a decent Hi-fi, but louder and more rugged/portable.
Already have some Pro equipment, but would like to have a go at making some good mid-tops myself, and looking for ideas as to what I should build/ power them with/ partner them with etc. Can spend up to a £1500, and already have some pro-drivers, power amps etc, but will buy new if needed.
Have the notion that 2 x 10inch + 1inch comp' driver might be the way to go, mainly because I can't stand the sound of most 15s + cds I have ever heard when used as tops/full-range speakersClick the image to open in full size.
But open to all ideas and experience tendered...
Thanks for reading my drivel.
Old 10th January 2010, 07:27 AM   #2
chris661's Avatar
Someone on here made something called the boominator, designed to be the ultimate portable system - let's hope someone has a link.
I remember it using 4 woofers (maybe 10", not sure) in a single box.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 10th January 2010, 07:57 AM   #3
frugal-phile(tm)
planet10's Avatar
When you said portable, i started thinking suitcase sized. But i see you mean luggage trolley.
Sure its doable. There are lots of possibilities.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th January 2010, 08:57 AM   #4
el`Ol is offline el`Ol  Germany
Just for making clear the dimensions: Could you accept the format of this kit? Bass drivers are eightinchers. Over 2000 Euro for two is a bit high, I know.
LSV Dieter Achenbach
Old 10th January 2010, 10:11 AM   #5
domtw is offline domtw  France
domtw's Avatar
I haven't seen that "Boominator" project before, but after a quick search,here it is.
Very interesting and cool profect !
Greetings & Soulful Salutations! soulray Introductions 3 9th January 2010 09:24 PM
5.1 to 4 channel solution tahngarth Digital Source 3 12th January 2007 06:58 AM
What if there was a one-box solution? ptwining Digital Source 1 27th December 2006 10:18 PM
Best Solution ?? cybtech Multi-Way 5 6th July 2004 10:26 AM
Page generated in 0.07241 seconds (83.36% PHP - 16.64% MySQL) with 10 queries
