Old 8th January 2010, 06:54 PM   #1
Default Eminence Kappa 15LFA vs PAudio C15-600EL
Hi to everyone!
Does anybody have any experiance with both, or some of this driver, and what you can tell on this producers in general?
Kappa 15LFA has 99dB, winder range 38Hz to 2700Hz and Fs 39Hz and is bit cheaper here, PAudio on other has 98dB, 30 to 1200Hz and Fs 42Hz.....I want to use it in 200 litre system as 2way with cut on about 800Hz...
What you think which driver would be better choice?
Old 8th January 2010, 08:55 PM   #2
Zvuchniak's Avatar
Hi MarinZ..
I was wondering, what do you want to use for the tweeter in this 2-way configuration ??? Which driver/horn combination would you use with one of this woofers?
Old 8th January 2010, 09:05 PM   #3
PAudio BM-D750 compression driver with 90X40 PH-2380 horn, driver is good and it's has 3'' coil so it will be enough energy to reproduce HF, and I was think on 800Hz crossover freq.
Old 8th January 2010, 09:43 PM   #4
Zvuchniak's Avatar
I would most definitly use the P.Audio woofer. With its Mms of 89gr and slightly stronger engine... It looks way better than Eminence.
Although i do not know how it will behave in 2-way configuration in that box. I would go for three way but thats just me
PAudio Drivers ilewis33 Full Range 17 25th June 2008 10:43 PM
Eminence Kappa Pro-12 tom_nice Swap Meet 1 26th February 2006 11:30 PM
3 way project - Morel 110 - PHL 1120 - Eminence Kappa Pro 15LF-2 Branwell Multi-Way 19 14th July 2005 02:21 PM
Eminence Kappa Pro 15LF-2 vs Peerless 12" XLS Branwell Multi-Way 5 26th July 2004 10:43 AM
PAudio DIY speakers chanmw Multi-Way 2 7th January 2002 03:21 AM
Page generated in 0.06932 seconds (69.83% PHP - 30.17% MySQL) with 10 queries
