hi
i'm building a two way speaker for my stereo and have bought dayton classic shielde woofer - 5 inch one and hivi dome tweeter - tn25 this is my first attempt at speaker building. I need all the possible help for the same and it should be a simple build. |
#2 | |
DC130AS-8 5-1/4" "A" Shielded Woofer Specifications Power handling: 30 watts RMS/45 watts max Voice coil diameter: 1" Voice coil inductance: .33 mH Impedance: 8 ohms DC resistance: 6.0 ohms Frequency response: 45-6,000 Hz Magnet weight: 9.5 oz. Fs: 43.4 Hz SPL: 88dB 1W/1m Vas: .61 cu. ft. Qms: 1.82 Qes: .51 Qts: .40 Xmax: 2.5mm Net weight: 2-1/2 lbs. Dimensions: Overall Diameter: 5-1/4" Cutout Diameter: 4-3/4" Mounting Depth: 3-1/8" Magnet Diameter: 3-3/8" Magnet Height: 1-3/8" the tweeter specs are HIVI TN25 Nominal Impedance (Z)(Ω): 5 Resonance Frequency (Fs)(Hz): 1500 Nominal Power Handling (Pnom)(W): 15 Sensitivity (2.83v/1m)(dB): 90 Weight (M)(Kg): 0.09 VC Diameter (mm): 25 DC (Re)(Ω): 4.6 VC Layers: 2 VC Former: CCAW VC Frame: ALuminum Magnet System: Shielded Magnet Former: Neodymium Recommended Crossover Frequency(Hz): >200 |
#3 |
Good, now you have complete series model for the woofer. Do you know how to use WinISD software for the speaker enclosure, for a start. (On tweeter, you mean rec. xover freq. >2KHz).
#4 |
i'm completely new to speaker building, i do have bass box and winisd so which one to use, and i dont know any thing of crossover etc
#5 |
2-Way Crossover Designer / Calculator
The above is the calculations for your passives. As a start, I will use 3000Hz as the cutoff points for them(considering tweeter should be X2 from its FS to be safe) and see how it goes. |
#6 |
you've got some reading to do
Designing Crossovers with Software Only FRD Consortium tools guide overwhelming? sure |
#7 |
It is difficult (near impossible) to find speaker components in Bombay.
Here are the cabinet dimensions: http://www.speakerbuilder.net/web_fi...ts/DBP/dbp.htm Now, we just need a series crossover--only two inductors (one per each speaker cabinet) to find or make or ship at great expense. Here is the tweeter: Parts-Express.com:*HiVi TN25 Fabric Dome Tweeter | Tweeter dome tweeter soft dome sheilded tweeter textile dome silk dome Here is the woofer: ![]() Parts-Express.com:*Dayton DC130AS-8 5-1/4" Classic Shielded Woofer | woofer dc130as-8 5-1/4"woofer midbass shielded woofer dayton dayton audio dayton loudspeaker I attempted to convert the super-spendy parallel crossover (made of parts that cannot be sourced at market) on this page: http://www.speakerbuilder.net/web_fi...P/dayschem.jpg to a series type crossover to reduce expense and make it more doable. Attached is my guesswork; but, can someone put in the correct component values? |
#8 | |
(L=>1,5mH, maybe 1,8/2,2mH on woofer), in the end I would adjust right padding on tweeter. |
#9 |
Pay attention (with max. power because) you will have (Xmax=2.5mm) cone excursions about double spec with only 20W @60/70Hz.
#10 |
I have used the TN25. I found it to be better than the price would suggest. A touch grainy, but quite satisfactory. I failed at my attempt to solder wires to them. I melted the sides of the enclosure, that is all.
I must confess my favorite music is that made by the Rolls Royce Merlin. |
| Page generated in 0.10788 seconds (79.82% PHP - 20.18% MySQL) with 10 queries |
