This is going to be the KISS box method of choice for me.
Can anyone recommend a quality set? |
#2 |
#3 |
In my experience using a tablesaw (assuming you have one) with a quality stacked dado set (Freud, Forrest) and dado shim set is much more flexible and will get the job done faster. In the last year I have had "3/4 inch" plywood that ranged from 0.688 to 0.749 in thickness...the dado with shims will let you match within 0.005". If a router is your only choice, go with top quality bits (Freud, Whiteside)...don't skimp on the cutting edge. Good luck!
Kevin
Kevin(ahcc20)...I'd rather have a bottle in front of me than a frontal lobotomy!
#4 |
Tubie Noobie
routerbits dot com has whiteside. Have a couple of nice sets with different bearings to set width of cut.
Living Life Doing the Waltz in 4/4 meter. |
#5 |
I'm happy with my 1/2 inch Linbide rebate bit. Linbide Tools; Saw Blade & Router Bit Manufacturer; Woodwork & Metalwork Tool supplier
#6 |
Thank you gentleman, I will look into this. I don't have much in the way of wood working tools and I really don't want to build a work shop to build a box
I have a quality router however so I think I will try using it. I will likely get a router table as well. I have more items to buy like clamps and a table top drill press so I am in for a few items... |
#7 |
Tubie Noobie
With a Good Router and a couple of straight edges you can do wonders. Add a router table and almost anything is possible.
| Safely using large router bits? | ShinOBIWAN | Multi-Way | 25 | 21st April 2008 08:10 PM |
| router bits for flush mounting | eisenhower | Multi-Way | 12 | 27th December 2006 01:24 PM |
| Heads UP. Super deal on router bits! | rcavictim | Equipment & Tools | 7 | 26th September 2006 03:17 PM |
| 24 bits DAC with 16 bits | guytou | Digital Source | 2 | 9th August 2005 10:40 PM |
| Joints for enclosures | CrisTUFR | Multi-Way | 14 | 4th June 2004 08:29 PM |
| Page generated in 0.08490 seconds (74.12% PHP - 25.88% MySQL) with 10 queries |
