I am needing help in calculations for a double high pass filter here what I have therorized see photo
#2 |
how does it work?
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#3 |
.5mh coil in parallel with the 3.3 uf cap is the regular second order hp filter around 3.2 khz, but I need it to taper off at 12 khz hi dispersion capability with the use of increase inductance this where the .05 mh coil in series, the other capacitor would kick in hopefully around 12khz or 13khz throught the other capacitor. The L pad is just to adjust the brightness of the Low tweeter
There are four possible tweeters for the low end tweeter and 1 tweeter chosen for the vhf Vifa XT25TG30-04 expected impedance is around 5 or 6 and 3.2, impedance at 12 khz needed to be determined and if I need more impedance Low end tweeter choices are: Vifa DQ25SC16-04, 1" Titanium Dome Tweeter (this is my first choice) D26NC-55-06 Pioneer FP66AP45-54F 2-1/2" Cone Tweeter to be tested and spec-ed Power handling: 40 watts RMS/55 watts max * Voice coil diameter: 1/2" * Impedance: 8 ohms * Frequency response: 2,000-20,000 Hz * Magnet weight: 2 oz. * SPL: 93 dB 1W/1m, second choice maybe for I need to see the FR data Bose 3 1/8 cone tweeter Power handling: 75 watts RMS/100 watts max * Frequency response: 2,000-20,000 Hz * Closed back design. Impedance: 4 ohms * Voice coil diameter: 1/2" * Magnet weight: 4.7 oz. To tested and spec-ed. |
#4 |
FWIW, I'd be inclined to go with a more conventional cascaded xover layout, tapering the required responsed with resistors across the 1.5uF cap & .05 mH coil...
#5 |
You low tweeter will have no output.
John k.... Music and Design NaO Dipole Loudspeakers. |
| DIY Low Pass and Mid/High Pass (Bass Blocking) Filters | runslikealpaca | Everything Else | 1 | 19th June 2009 10:59 PM |
| High Pass Crossover for FE87E (Protection) | mrevie | Multi-Way | 8 | 15th April 2009 09:34 PM |
| high pass filter (crossover) | derekyu | Multi-Way | 8 | 30th March 2007 05:32 PM |
| Need High level, high pass crossover for 250watts | Anthrax | Multi-Way | 0 | 21st January 2007 03:34 AM |
| high pass crossover - active, passive, simple or complex? | nick78 | Parts | 1 | 23rd May 2006 06:43 AM |
| Page generated in 0.08453 seconds (73.90% PHP - 26.10% MySQL) with 11 queries |
