"Best" Woofer 50Hz - 300Hz & Hi eff, maybe 15" ?? - Page 4 - diyAudio
Old 11th January 2010, 07:50 PM   #31
Defo is offline Defo  Norway
Jbl 2226h
Old 11th January 2010, 08:00 PM   #32
InclinedPlane's Avatar
Agreed. JBL pro stuff is absolutely top of the line.
I must confess my favorite music is that made by the Rolls Royce Merlin.
Old 11th January 2010, 08:04 PM   #33
ScottG is offline ScottG  United States
Originally Posted by bear View Post
..thinking to myself that of the lot the Focals might be the best sounding.
Tonal quality and fidelity are the criteria that I'm concerned with - natural sound - Mingus ought to sound like his bass is in the room... and not sound like someone else's instrument... and of course maximum sensitivity.
That sounds about right.. BUT it does depend on the amplification. The Polyglass woofers with the stronger motors didn't do anything particularly wrong, and did almost everything well. The amplification and the loading tended emphasize one particular quality better, but at the expense of other qualities. Overall *supple* is the word that comes to mind, the newer glass sandwich versions are more detailed (for a given motor), but don't have quite the same quality.
Again though, I'd encourage you to go back and read that post I linked to (..and as expensive as the Supravox field coil is, it's generally less expensive than most, if not all, other field coils of similar size). (..of course only once the AA board is working.)
perspective is everything
Old 11th January 2010, 08:28 PM   #34
chrismercurio's Avatar
you may want to consider reading the stuff over at the lansing heritage board...there have been a few threads on best 15" woofer
Old 12th January 2010, 02:27 AM   #35
Banned
A few things here...
a horn is not an option in this system.
the higher the sensitivity the better in terms of matching.
a single driver in 15" is the limit in terms of space. 2 x 12" is feasible...
I've got experience with the Altecs, the JBLs and the Focal 15 series... thinking to myself that of the lot the Focals might be the best sounding.
Again, I do not want or need to go below ~50-60Hz. I've got killer subs for that area.
Upper bass to die for? Ideas are nice, actual experience is better.
_-_-bear
PS. the JBLs sound ok, but have a kinda dead and non dynamic presentation - and maybe don't reach their sensitivity specs? Maybe they are better than what I just said... but I'd maybe tend toward a K140 or earlier driver... dunno.
To ask for the best, say you can build any box and then say a horn is not an option is really backwards "bear" Good luck with your compromise
Old 12th January 2010, 02:59 AM   #36
dcathro is offline dcathro  Australia
If you like the JBL k140, you might like these:
A150WVL | Kilimanjaro-Series | Wolf von Langa
These are a field coil K145.
I bought a pair to use in my project for AU$3000 inc shipping. Everyone who has seen them has thought them very good value for money.
It is too early for me to give a definitive statement on them, but so far I am very pleased with them. They don't go low (below 40Hz), but are warm and very clear and fast. I also love the tuneability of the driver parameters.
_-_-bear
Old 12th January 2010, 12:40 PM   #37
expert in tautology
bear's Avatar
No it is not a good option.
A horn will not readily "time align" in most instances, unless you want the thing sticking out into the listening space by a significant amount, and you can deal with the offset that will be required to prevent shadowing of the HF section. If I had an utterly huge room, I'd give it some consideration, I don't.
Also I have heard few "bass horns" that really sound that good overall, most simply don't get low enough - and few are actually flat in the passband because the mouth size is way too small...
And I also said that this system has a killer subwoofer section, so I am looking for a "filler driver"... ~60Hz - ~250Hz.
shall we go on?
Anyhow, the topic is fairly clear and simple... "direct radiator upper bass drivers - likely 15" & high sensitivity". Ok?
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 12th January 2010, 12:50 PM   #38
expert in tautology
bear's Avatar
Regarding the other suggestions - all appreciated.
The Lambda drivers are doubtless good, but don't quite "scream" being that their sensitivity is mid 90s, and they are designed with the phase plug to "go high" - which I don't need or want. A rolloff starting at 500-1000Hz would actually be desireable!
The older Altec drivers might suffice, but then we have to consider the TAD 1601 as a newer version, and of course the Focal 15 series is also a clone.
As I mentioned, the JBL drivers are of interest, but they tend to sound (to me) a little "dead" and perhaps undynamic. Perhaps this is because they are relatively clean (distortion wise) drivers, but still they come off as a little dead sounding and do not seem to really be high 90's SPL sensitivity despite their claims, more like 96dB SPL/1w.
Fancier drivers that cost beaucoup $$ are not going to get into the mix here. The treasury department will not finance that. Contributions are always appreciated. Although they are of some interest.
I'm giving some additional thought to the multiple driver solution (line array, even if not array'd in a line...).
There seem to be a few Eminence drivers that spec at a true 100dB whose specs don't look too awful... but I am suspicious of their cone formulations/designs - the HF rises look a lot like break up modes...
_-_-bear
_-_-bear
Old 12th January 2010, 03:42 PM   #39
~100db single woofer... JBL D130?
I simmed it in a big@ss box and it's 100/101db 1w/2.83v in 2pi space with the kind of extension you want. I have only heard them in some screaming guitar amplifiers but will remain forever impressed by the combination.
regards,
Old 12th January 2010, 04:43 PM   #40
el`Ol is offline el`Ol  Germany
http://www.ciare.com/pdf/catalogo/CS250.PDF
Very old-school.
Low moving mass, low excursion, cloth surround, would give 93 dB in 60 l sealed, but only -5 dB at 60 Hz.
Probably there are similar drivers from Madisound.
Woofer for below 300Hz in an OB sfdoddsy Multi-Way 38 20th December 2013 10:24 AM
suggestion for a 15 inch, under 200$ each that is good from 35hz to 300hz murphythecat8 Multi-Way 34 24th November 2012 03:50 AM
hight eff woofer that can be run W/O crossover rvrazvan Multi-Way 13 5th November 2011 08:10 PM
Lowest distortion (sub?)woofer up to 300hz? Spasticteapot Subwoofers 1 28th August 2010 09:42 AM
Looking for a ~40-300Hz Horn solution with a 15" Driver Bass-Depth Multi-Way 20 1st April 2006 05:19 PM
Copyright 1999-2017 diyAudio
