"Best" Woofer 50Hz - 300Hz & Hi eff, maybe 15" ?? - Page 15 - diyAudio
Old 23rd November 2011, 03:15 PM   #141
EBA is offline EBA  France
Hi bear,
What are the S / T parameters of your ADIRE DPL 12 mount on your quadripole ?
Adire is done.
EBA
Old 24th November 2011, 02:52 AM   #142
expert in tautology
bear's Avatar
T/S I have to guess, because it is so long ago now and I am not near my notes...
I think Qt is ~0.4 maybe a little less 0.38?
VAS was ~4cuft...
Fs maybe 22Hz??
I dunno, +/- some %...
The real specs are likely online somewhere...
The system gets some increase in sensitivity because the two cabs per channel are in parallel.
But I use a large SS amp (Crown MacroTech) with high DF... also these drivers are/were what I used as the second iteration, when those drivers were still new and fresh... keep in mind that I use them only BELOW ~65Hz... 4th order rolloff with the -3dB point at 65Hz.
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 24th November 2011, 05:47 AM   #143
Brett's Avatar
www.adireaudio.com/Files/OldAdireDrivers.pdf
Old 24th November 2011, 12:11 PM   #144
Thank's Bret,
Bear,
Your DPL12 have a very low eff = 84 db x two speakers = 87 db
We don't say " i do " with a Hight EFF bass speakers !!!
Best regards
EBA
Old 24th November 2011, 03:51 PM   #145
freddi is offline freddi  United States
freddi's Avatar
Tom's generational record/playback test must be stringent as colorations which are bearable in listening pile up noticeably just in the first recording.
I tend to like lower mass woofers as toying around with 2-ways with higher crossover points, it seems a better tradeoff - could be my compromised hearing.
re: SC15 neodymium Peavey (TS same for 1508-8HE ferrite version other than 1K watt program)
- Znom (ohms) 8
- Revc (ohms) 5.32
- Sd (Square Meters) 0.084
- BL (T/M) 16.04
- Fo (Hz) 51.2
- Vas (liters) 182.4
- Cms (uM/N) 182.0
- Mms (gm) 52.90
- Qms 10.60
- Qes 0.352
- Qts 0.341
- Xmax (mm) 1.9
- Le (mH) 0.34
- SPL (1W 1m) 100.3
- No (%) 6.70%
- Vd (cu. in. / ml) 19.5 / 319
- Pmax (Watts pgm.) 1300
- Disp (cu. in. / ml) 197/ 3229
Old 24th November 2011, 04:12 PM   #146
dirkwright's Avatar
This is what I'm planning on doing. It's a B&C 15BG100 in a 80liter box tuned to 32Hz. Sensitivity is a little above 90dB, and it's good to 30Hz with room gain.
Old 24th November 2011, 06:49 PM   #147
KSTR is offline KSTR  Germany
KSTR's Avatar
Originally Posted by EBA View Post
But one parameter didn't mentionned.it's the FA factor ( Acceleration factor ) = BL/MMS . This parameter is the most important for the dynamics and the physical impact.
Please use BL^2/(Re*Mms) instead. Otherwise you DO NOT factor out the coil resistance and you DO favor drivers with high Re, which is not correct.
Old 24th November 2011, 07:03 PM   #148
KSTR's Avatar
Originally Posted by Overkill Audio View Post
PD1550
I had those in OB and wasn't amused (), they bottom out so easily. The quality for the price is very OK, though.
The Beyma P80's have twice the Xdamage, in comparison.
Old 24th November 2011, 07:34 PM   #149
Overkill Audio's Avatar
Talking Over drive a PD1550...RESPECT DUDE!!
Hi KSTR,
Wow, you managed to over drive the PD 1550 to the point where it bottomed out...that must have been loud...! Its AES rated to 600 watts continuous with a genuine sensitivity of 99 dB/1 watt at 1 meter so thatís a clean 125dB with 512 watts...still well under max power...And you did this in a domestic setting...how big is your lounge?!!
I never even approached the limits of my Beyma 15 SM115K and they have a lower sensitivity and a lower power handling.
Subjectively the PD's are much cleaner and lower distortion giving better impact on drums and better detail and texture on acoustic bass.
What 15 inch drivers have you used in open baffle that outperform the PD 1550's?
Thanks in advance and all the best
Derek.
Old 24th November 2011, 08:10 PM   #150
Which is basically sensitivity/efficiency...
Woofer for below 300Hz in an OB sfdoddsy Multi-Way 38 20th December 2013 09:24 AM
suggestion for a 15 inch, under 200$ each that is good from 35hz to 300hz murphythecat8 Multi-Way 34 24th November 2012 02:50 AM
hight eff woofer that can be run W/O crossover rvrazvan Multi-Way 13 5th November 2011 07:10 PM
Lowest distortion (sub?)woofer up to 300hz? Spasticteapot Subwoofers 1 28th August 2010 08:42 AM
Looking for a ~40-300Hz Horn solution with a 15" Driver Bass-Depth Multi-Way 20 1st April 2006 04:19 PM
Copyright ©1999-2017 diyAudio
