how to cut plexiglass? - diyAudio
Old 30th May 2003, 02:30 AM   #1
Default how to cut plexiglass?
hi
i am trying to build an open baffle speaker based on the following design. anyone have any bright ideas on how to make an 8inch cutout in a sheet of plexiglass, to mount the drivers?
cheers -
pradeep
Old 30th May 2003, 02:35 AM   #2
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I used router to cut those openings in 2.5" acrylic. It was almost like working with wood.
Who makes the speaker in your pic? Looks interesting.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 30th May 2003, 02:41 AM   #3
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Looks like peter's new project FILL us in Peter. Design's and ideas. More pic's. Also looks like your going to be useing a ribbon tweeter. is this True...?
Old 30th May 2003, 04:16 AM   #4
The opening is for Raven 2. The midbass units will be Triangle. I plan to mount this in a wall between 2 rooms in a basement, so basically it is open/infinite baffle.
www.audiosector.com
Old 30th May 2003, 04:19 AM   #5
Banned
pic's of the driver's..?
Old 30th May 2003, 04:25 AM   #6
http://orcadesign.com/companys%20pro...rs/raven2.html
www.audiosector.com
Old 30th May 2003, 05:34 AM   #7
jam is offline jam  United States
jam's Avatar
Peter,
Looks like a great project, how about a new thread and step by step construction pictures.
Jam
Old 30th May 2003, 05:34 AM   #8
Banned
YEAH!!!!!!
Old 30th May 2003, 07:06 AM   #9
Default link to manufacturer of open baffle speaker above...
http://www.dietiker-humbel.ch/micromag.htm
(scroll down for views of the above speaker). it uses a single PHY-HP speaker driver.
cheers -
pradeep
Old 30th May 2003, 07:50 AM   #10
taufern is offline taufern  United States
Location: Northwest United States about an hour north of Seattle WA
psarin i did car stereo for about 18 months before i enventually ended up doing what i do now (US NAVY) and did a bunch of plexi work...a router bit is the best way to cut it...and if youre thinking about getting creative you can heat it and bend it too as long as its not much more than a half inch thickness...but then again you'd probably want at least 3/4" for optimal stiffness...the router bits will probably get pretty worn down even for a project this small...i'd probably go through a set of 80 dollar bits for every two or three projects...just something to be cautious of...
Plexiglass PCB GlidingDutchman Everything Else 4 23rd April 2008 02:57 PM
My latest subwoofer - a bridge opa549 built onto a piece of plexiglass soundNERD Chip Amps 23 13th January 2005 07:56 PM
Mounting Subs in Plexiglass Ky_0686 Car Audio 4 18th October 2004 10:05 PM
Plexiglass Enclosures avatar307 Multi-Way 3 25th December 2003 12:49 PM
Copyright ©1999-2017 diyAudio
