Old 7th January 2010, 02:18 AM   #1
Defo is offline Defo  Norway
Default Using the Accuton C50 widerange.
I was taking a look at the Accuton C50 and it seems to have a very wide bandwidth from 800-20khz, and with good sensitivity.
Have anyone tried, or have any opinion with this mid-tweeter? Of course with a woofer used below 800 hz...
Old 7th January 2010, 05:07 PM   #2
Bump
Old 7th January 2010, 06:03 PM   #3
Inductor's Avatar
Originally Posted by Defo View Post
Bump
Defo what's your idea?
Never used that design. What makes you want (with prices in the hundreds $/€), maybe to have it on the high frequencies with a low xover point with the woofer/midwoofer, ala ATC-dome (w/Fs=400Hz), with the advantage of no need for a tweeter.
Another similar model (1/4 price/but a midrange design) is the TangBand WF SERIES W4-1805S.
Old 7th January 2010, 06:54 PM   #4
My idea is to find a small driver which can cover 500-20khz with decent sensitivity, and couple it to a large waveguide. Small fullranges usually have very low sensitivity and poor power handling. I dont know why Accuton have listed it as 800-12khz when their freq graph and distorsion data easily reaches 20khz though.
Old 7th January 2010, 07:48 PM   #5
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
This driver is about 2 inches diameter? Likely Accuton gives recommendations for the extreme high end application their drivers are used intended for, so off-axis behaviour at high frequency will not be excellent for a 2" driver.
Nice looking driver, but the price tag on Accuton drivers makes them look a bit ridiculous to me.
The power of Science compels you!
Old 7th January 2010, 08:22 PM   #6
ScottG is offline ScottG  United States
I was looking at it recently.. for it's extended bandwidth, but NOT for a waveguide.
It's a 2 inch driver and it's response above 4 khz has a bit of a loss in pressure, more so when you consider that it's right around this region that a 2 inch driver will start loosing pressure off-axis.
Because of this most waveguides will result in a *very* depressed response above 5 kHz. If you are looking for something with wide bandwidth and eff. then this is NOT the solution for you.
Also at around 250 US, it isn't exactly cheap either.
I could see a large "shallow" waveguide on a SB Acoustics SB25STC.. (..though not for operation as low as 500 Hz.)
perspective is everything
Old 7th January 2010, 08:54 PM   #7
Troels used it (old name C2-44/8):
SP44ScanSpeak 18W/
Usefull comparison "new/old name" sheet:
http://www.clofis.nl/nl/thiel/Thiel%...s%209-2006.pdf
crazyhub
Old 7th January 2010, 09:19 PM   #8
I suppose you are refering to off axis dispersion and beaming issues? How does it compare to other larger full range drivers in this department?
Isnt that common with waveguide loaded tweeters? A tilted down response because of the low end loading. With eq I dont see this as a problem, or is it more to it?
Old 7th January 2010, 09:22 PM   #9
SP44ScanSpeak 18W/
It seems the new one (C50) has a lot higher sensitivity then the older model?
Old 7th January 2010, 09:42 PM   #10
..it's all about sd (assuming no "phasing" device in front of the driver with an otherwise "tilted-up" response on-axis).
2 inch drivers spherical (convex or concave) will all have about the same loss in pressure off axis at about the same freq.. (..cantenary drivers can sometimes marginally improve on the upper freq. loss, and of course compound drivers like the recent "ring" type variety can act as small sd for higher freq.s and larger sd for lower freq.s.)
There is "more to it" (literally) with a 2 inch driver, and particularly with *this* 2 inch driver (because of it's response on axis at higher freq.s relative to the rest of it's lower freq. bandwidth).
The loss in pressure at higher freq.s you commonly see with 1 inch drivers will become exaggerated with 2 inch drivers. Less pressure off-axis provides less pressure for the waveguide to work with. More so with this particular driver because of its response at higher freq.s is a bit depressed in level relative to the response around 3 kHz. It wouldn't be an easy couture to eq., and you would effectively end-up with a *less* eff. driver.
Possible to add digital output to my old Sony CDP-C50 CD player? morkys Digital Source 4 9th July 2009 10:28 PM
Want to buy: ACCUTON C50-8-44 Henckel Swap Meet 0 11th April 2009 06:39 PM
Suprabaffle for widerange + tweeter? fred76 Full Range 3 3rd May 2007 06:57 AM
CD player indentical to Sony CDP-C50 but with digital toslink output? morkys Digital Source 0 8th April 2004 01:18 AM
Widerange Driver 2-Way project LageB Multi-Way 1 30th March 2004 06:58 AM
Page generated in 0.12336 seconds (80.54% PHP - 19.46% MySQL) with 10 queries
