a Pair of Aiwa Woofers and Tweeters Removed from a Cheap Aiwa Speaker System....the Woofers are Video Shielded and have Odd Plastic Baskets....they are Awfully Airy,and sound Decent Full Range...the Tweeters are typical Cheap Cones....wonder how they would compare to a Equivilent Dome?
anybody got any Reccomendations for this? |
#2 |
Do you have a measurement setup?
What do you want to do? |
#3 |
Banned
Put them in the loft or garage for some years then throw them away. Alternatively, save time and effort and throw them away right now. You've got no spec for them, they're cheap and they're not worth investing effort in.
Oh, you could give them to some kid to make a home-made boom-box, but be careful not to get taken for a paedo.. w |
#4 | |
![]() Based on some Sweeps id Put the Usable Range at 50 Hz-14 Khz |
#5 |
re:'Put them in the loft or garage for some years then throw them away' LOL, been there, done that, but don't be so quick to diss these, I have made a couple of OK sets of speakers from similar drivers - but you do need to test them to see whether to discard or not.... - cone tweeters - typically need to be used higher than domes, say 4KHz up, most have a fairly peaky response & fall off high, but there are some gems out there... (matsushita/panasonic are definitely worth the trouble to test...)
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#6 |
the name "Aiwa" comes from 'I a wish I threm away" aiwa was never going to work, aiwa sorry i ever bought these things. Not being rude, but suck, that is why their car audio side never made it. However, it is a project, so good luck. no hard feelings.
#7 |
I'd be throwing the tweeters in the bin but keeping the other driver as a cheap mid, mated to a 3/4 or 1/2 inch dome crossed high.
Go 2.5way to a cheap 8inch or bigger, but while definitely probably usable without measurements it will tale a while to tweak to listenable ******* Audax 10mm polymer dome tweeters ******* - eBay, Speakers, Subwoofers, Audio, Electronics. (end time 10-Jan-10 04:33:33 AEDST) This little tweeter would mount centrally and all it needs is a 1.5/2uF cap in front
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#8 |
there was no coil in between the crossover, only a single,- small capacitor, right...?
#9 |
#10 |
the same ....highend.. here..
![]() ![]() disclaimer: pls dont blame me for reverse engineering.. the drivers where in 7L BR as i can remember. PS: sorry the 830883/27tdfc guys waiting for conclusions about my project. tweeter advice for peerless 830883 //www.diyaudio.com/forums/multi-way/126423-tweeter-advice-peerless-830883-a.html no time to solder my tsp aparature as said... :/ Last edited by flexus; 3rd January 2010 at 10:03 PM. |
| Dynaco A25 drivers. Four woofers, 2 tweeters. | nodiak | Swap Meet | 1 | 8th December 2007 04:33 PM |
| WTB: Scanspeak 8545 woofers, tweeters | ssmith | Swap Meet | 5 | 9th March 2007 10:18 AM |
| Korean Woofers/Tweeters | caratje | Multi-Way | 8 | 28th January 2005 01:44 PM |
| Matching effeciency between tweeters and woofers? | RyanP3H | Multi-Way | 2 | 20th February 2004 05:05 PM |
| FS:SS 8545 woofers, Audaux PR120I tweeters, Volt BM2500.4 Woofers | cm7 | Swap Meet | 0 | 1st August 2003 01:59 PM |
| Page generated in 0.09962 seconds (80.95% PHP - 19.05% MySQL) with 11 queries |
