Smooth break-up - Page 6 - diyAudio
Old 7th January 2010, 07:53 AM   #51
Alex from Oz's Avatar
Originally Posted by CLS View Post
How can 1 & 3 above be done?
For 1 - a variation of the EnABL process.
For 3 - PM me for that one (sorry)
Alex
Old 7th January 2010, 03:22 PM   #52
InclinedPlane's Avatar
Originally Posted by thadman View Post
It would still serve the same function as the surround. The motion must reduce to zero somewhere.
Sure. But I was thinking about the sonic advantages. The cone would not be reflecting off anything and there would be no transition from pistonic to non-pistonic movement.
I must confess my favorite music is that made by the Rolls Royce Merlin.
Old 7th January 2010, 08:08 PM   #53
thadman is offline thadman  United States
At the interface between the cone and spider, an impedance match exists just as an impedance match exists at the cone-surround interface. This interface will possess resistive as well as reactive components. Energy will be reflected back into the cone due to the reactive components. There is no free lunch here. Motion must reduce to zero somewhere, otherwise it will not be moving in reference to anything and no pressure variations (ie sound) will result.
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them."
Old 7th January 2010, 08:19 PM   #54
I'm not trying to force you to think it's a good idea. I'm building one; in the spirit of DIY.
Old 28th April 2010, 06:56 PM   #55
dantheman's Avatar
check out this break up behavior:
Response is gated at 3 milliseconds, 1/12 octave smoothed, one meter at the top of the basket from 11.25 degrees off central axis to 90 degrees in 11.25 degree steps. I think this shows why measuring well off axis is important.
Anyone know of this is typical behavior? Anyone else want to post some graphs for public viewing?
Dan
My Blog
My Music Recordings
Old 29th April 2010, 12:37 AM   #56
dantheman's Avatar
could this also have something to do with baffle edge diffraction?
My Blog
My Music Recordings
Old 29th April 2010, 02:00 AM   #57
CLS is offline CLS  Taiwan
A cone without surround, hmm... isn't that (sort of) a big whizzer?
As the wave propogating, a free edge has the same reflection amplitude as a solid wall, doesn't it?
So, eventually, the breakup would probably be more complex (if not stronger).
Smooth Jazz Puffin Music 11 9th June 2010 03:51 PM
Smooth OpAmp output stage. wandelblu Chip Amps 1 2nd February 2008 10:25 PM
Other options to smooth baffle diffraction Dave Bullet Multi-Way 7 7th July 2007 05:36 PM
smooth tone palesha Multi-Way 0 22nd September 2003 01:36 AM
Need to smooth upper bass of sub response... eRiCdWoNg Subwoofers 4 27th August 2003 03:01 AM
Copyright 1999-2017 diyAudio
