Old 7th January 2010, 01:08 AM   #41
Alex from Oz's Avatar
Originally Posted by InclinedPlane View Post
I think there might be. A surroundless driver, using 2 spiders; one above the top plate and one several inches below the back plate.
Do you have a link or is it just an idea?
Old 7th January 2010, 01:18 AM   #42
InclinedPlane's Avatar
Oh! No, an idea only.I would love to build it, if I had access to a few $million of equipment!
I must confess my favorite music is that made by the Rolls Royce Merlin.
Old 7th January 2010, 01:27 AM   #43
CLS is offline CLS  Taiwan
Originally Posted by dantheman View Post
Here's polars on the PE 12"WG combined with a 15" woofer:
Interesting, and thanks a lot for sharing
If you don't mind, I have some questions:
1. What's the driver working with the WG?
2. Any mods on the throat of WG (and/or the adaptor)?
3. Can you trace the causes of those 'glitches' around 8~11kHz?
I apologise if those have been brought up before.
Old 7th January 2010, 01:31 AM   #44
Originally Posted by Alex from Oz View Post
These are my cone treatment goals in order of importance:
1. Maximise cone to air energy transfer
2. Minimise the reflected energy within the cone
3. Maximise surround to air energy transfer
How can 1 & 3 above be done? Or the statements are limited to a certain condition (a certain range of frequency, amplitude, or the likes... )?
Old 7th January 2010, 02:03 AM   #45
dantheman's Avatar
Your welcome!
1. Eminence ASD1001S
2. No, the throat needs work. It definitely doesn't match up well.
3. My guess is that #2 is the what's causing #3 After I fix the throat I'll know better. They may be inherent in the driver to some degree. It's hard for me to say b/c the other horns I've put it in are very rough.
Here's the same compression driver inside the same 15" woofer on it's coaxial horn on axis:
11.25 off
22.5 off axis
33.75 off axis:
45 off axis
Hope that helps,
Dan
My Blog
My Music Recordings
Old 7th January 2010, 03:21 AM   #46
thadman is offline thadman  United States
It would still serve the same function as the surround. The motion must reduce to zero somewhere.
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them."
Old 7th January 2010, 04:09 AM   #47
Ah! I remember it now. It's indeed brought up before: “Loading” of tweeters in large drivers Coaxes
(and the next)
Sorry
Old 7th January 2010, 04:34 AM   #48
dantheman's Avatar
(and the next)
Sorry
No worries. At least you didn't get it all messed up this time. Just teasing man. No hard feelings?
Dan
My Blog
My Music Recordings
Old 7th January 2010, 05:20 AM   #49
So maybe there is a place for the Fertin Acoustic 20ex Model 7 Field Coil Driver with no surround ...
Old 7th January 2010, 05:36 AM   #50
dantheman's Avatar
For $2200 each, it won't be my house.
Very interesting concept however, but for now I'll stick with my problematic surrounds. Maybe this technology will trickle down some day.
Dan
My Blog
My Music Recordings
Smooth Jazz Puffin Music 11 9th June 2010 03:51 PM
Smooth OpAmp output stage. wandelblu Chip Amps 1 2nd February 2008 10:25 PM
Other options to smooth baffle diffraction Dave Bullet Multi-Way 7 7th July 2007 05:36 PM
smooth tone palesha Multi-Way 0 22nd September 2003 01:36 AM
Need to smooth upper bass of sub response... eRiCdWoNg Subwoofers 4 27th August 2003 03:01 AM
Copyright ©1999-2013 diyAudio
