Old 3rd January 2010, 02:40 AM   #1
Monroe is offline Monroe  Canada
Default Zaph ZRT - Bracing question (re: 'holes' in braces)
I am 90% of the way through building a Zaph ZRT: Zaph|Audio - ZRT - Revelator Tower
This speaker is a floorstanding two way ported design.
A friend built the cabinets for me out of baltic birch plywood, following the design on Zaph's site.
The braces/shelves have been ventilated, but the holes are not particularly large or numerous compared to most builds I have seen. The hole coverage area is perhaps 10%; see photo attached.
My question: Am I likely to have problems if I do not increase the number of holes in the braces?
I understand that the woofers have to see a certain air mass; would undersized holes in the braces change the effective volume/air mass? Would other problems arise?
The braces are not removable and it will be difficult to add more holes at this stage. Do I need to add more holes?
Thanks!
Old 3rd January 2010, 02:55 AM   #2
Andersonix's Avatar
I think you can get in there with a 3(?) inch diameter hole saw, as I think it's not open enough now. Or use the technique of drilling small holes around the perimeter of the holes you want, and then filing or sawing the rest.
Old 3rd January 2010, 05:40 AM   #3
DIFORCE is offline DIFORCE  Australia
I dont think it's enough ,the scanspeak moves alot of air
Old 3rd January 2010, 06:23 AM   #4
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
You need to lose around 50% of the shelf brace material to allow good airflow. A shelf brace combines a cross brace and horizontal brace so needs material around the perimeter as well as a + in the centre to join the opposite panels in each direction.
If you can't do that then get a jigsaw or small handsaw and join the dots so the complete middle is open.
The 18W8531 does move quite a bit of air.
No longer DIY active
Old 3rd January 2010, 07:12 AM   #5
frugal-phile(tm)
planet10's Avatar
Make some holes. given their orientation... rabbitz 50% is probably a good target.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 3rd January 2010, 02:33 PM   #6
Thanks! I will do my best to open them up.
What is the function of additional holes? Is a lot of air actually moving from one section to another, or am I simply allowing space for the waves to travel without being reflected back up?
Old 4th January 2010, 03:23 AM   #7
Also:
Are there any other improvements which I can make to the cabinet at this stage?
Right now, it has a lining of acoustic foam, and nothing else. I will be stuffing the cabinet at the bottom, per the plans.
Is there anything else that I can do to improve the cabinet? Other lining materials?
Old 4th January 2010, 05:58 AM   #8
Volenti is offline Volenti  Australia
The way it is now you run the risk of having the "tuning" of the spaces+the holes (think of them as ports) effecting how the driver behaves, they become individual little resonant cavities instead of one big one that's tuned the way you intended.
Old 4th January 2010, 07:05 AM   #9
rabbitz's Avatar
The area of the brace is around 437cm² so 50% cut out would give around 218cm². This looks OK as is larger than the SD of the 18W which is 150cm².
I think the minimum required would be a bit more than the SD of the driver. However, a single large hole would work differently to several quite small holes so put more holes in than you actually need to make up the area.
I hope I haven't confused things.
Old 4th January 2010, 06:30 PM   #10
Andersonix's Avatar
Maybe you could work faster with a 90-degree chuck adapter thingy(?)
Help with first Build (Seas CNO MkII or Zaph ZRT) whimsical Multi-Way 2 6th July 2009 05:40 PM
Holes in braces? screamersusa Subwoofers 2 29th December 2008 01:12 PM
Zaph ZRT -vs- ProAc 2.5 clone jallenbass Multi-Way 4 23rd August 2008 02:15 AM
Expanding TO-3 Holes/ Dremel question lgreen Solid State 58 17th June 2005 06:47 AM
simple bracing question... ChesterFuzzin' Multi-Way 20 27th June 2003 05:27 AM
Page generated in 0.12783 seconds (81.69% PHP - 18.31% MySQL) with 11 queries
