Old 2nd January 2010, 08:21 AM   #1
akis is offline akis  United Kingdom
Default Speakers RS 249-047
Hi
I have 4 of the above speakers which would like to use in a project guitar/keyboard amp. They are 6.5", wide range, twin cone. They are 15 Ohm each. What I do not know is their power rating, it is not mentioned anywhere. Is there a way to determine it somehow? I do not want to burn them by mistake.
Old 2nd January 2010, 08:39 AM   #2
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
http://it.rs-online.com/web/0249047.html
looks like 25w
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 2nd January 2010, 09:18 AM   #3
Ah great thanks. Therefore I will place 2 pairs of parallel in series getting 7 Ohms total and 100 Watts.
Old 3rd January 2010, 01:37 AM   #4
poynton's Avatar
That would be 15 ohms
( 2 in // give 7.5 ohms plus another 2 in // = 15 ohms)
So you're building a miniature 4 stack - 4 x 6.5" rather than 4 x 12"
I would rate it at 50w continuous - 100w max peak
Andy
Old 3rd January 2010, 07:49 AM   #5
Ah damn yes, they are 15R not 7R each. So I can do either 15R or 3.75R (which I think is too low).
I am thinking of using a 2x25V 80VA transformer I have in the spares box. That should allow for approx. 41 Watts into the 15R load. (trans is rated 230V 11% reg, my mains is 249V, assuming 4 volts drop at the rails).
I am building a small-ish amplifier, something you can carry around easily without major headache (the other amp I made is almost impossible to carry anywhere).
And because the speakers are "wide frrequency range" I will be able to plug in the keyboard or the mp3 player or other instruments, not just the guitar. Normal guitar speakers almost stop working over 4K-5K and cannot really plug in anything except a guitar.
249 Tube Wanted lpd Swap Meet 2 25th March 2009 03:56 PM
Want advice on refurbing old speakers using RS 1354a s. careless Full Range 1 3rd April 2008 05:42 PM
RS 40-1197 full range speakers for sale punk Swap Meet 1 3rd April 2006 10:38 PM
Philips 047 TT - no music, only buzz Rudy Verkorst Analogue Source 3 7th February 2006 08:20 AM
BD 249/250 for ESP P3A amp mik Solid State 10 14th December 2003 10:00 AM
Page generated in 0.08311 seconds (76.44% PHP - 23.56% MySQL) with 10 queries
