75 degree waveguide, any good reason?
Old 1st January 2010, 02:15 AM   #1
dantheman is offline dantheman  United States
dantheman's Avatar
Default 75 degree waveguide, any good reason?
If you using a 75 degree waveguide tweeter with a direct radiating Mid driver, won't you have to crossover above the pistonic range if you want matching directivity? In other words you'll have midrange cone breakup in you response.
Does that seem correct?
Is there any reason you'd want this directivity pattern?
Thanks,
Dan
My Blog
My Music Recordings
Old 1st January 2010, 07:06 AM   #2
gedlee is offline gedlee  United States
gedlee's Avatar
Thanks,
Dan
Dan
There is not enough information to answer this question.
Earl Geddes Gedlee Website
Old 1st January 2010, 07:19 AM   #3
dantheman's Avatar
a 90 degree WG tweeter can be crossed to a woofer approximately at the wavelength of the woofer's diameter to match directivity at the crossover point. Both would then be essentially 6dbs down at 45 degrees off axis correct?
Dan
My Blog
My Music Recordings
Old 1st January 2010, 07:50 AM   #4
gedlee's Avatar
Dan
Basically that is correct, yes. Why? In detail, it might differ somewhat.
Old 1st January 2010, 08:27 AM   #5
dantheman's Avatar
Exactly what I was thinking.
So why does Parts Express build a 75 degree waveguide which in my measurements are down 9 dBs at 45 degrees. My ten inch woofers then have to be crossed higher into their break-up region in order to match them. About 2.5 kHz instead of 1.5kHz for a 90 degree WG. It seems a 75degree WG would only make it harder for the DIY community to get their design right by doing this--there's a good chance the woofer's response will be rippled and have an erratic decay plus the center to center spacing at the crossover frequency will be further apart. So I figure there must be a good reason to build such a device. My guess is that it will work better in larger rooms b/c it can minimize early reflection problems. It seems that the benefit wouldn't outweigh the advantages in anything but a large have or gymnasium or if you are concerned with mastering your own score. Any other input?
Thanks,
Dan
My Blog
My Music Recordings
Old 1st January 2010, 08:31 AM   #6
dantheman's Avatar
Oh one other question someone smarter than me might be able to answer: is there an equation that would accurately predict a driver's beaming behavior if pistonic behavior is assumed at all frequencies(even though I know this does not actually exist)?
Thanks again,
Dan
My Blog
My Music Recordings
Old 1st January 2010, 07:32 PM   #7
LineSource is offline LineSource  United States
LineSource's Avatar
From Altec literature...
Variable ka is the ratio of the circumference of the speaker, or baffle, to a wavelength. High ka numbers indicate high frequency. A loudspeaker will be omnidirectional starting at ka=1 and the beamwidth will halve for each octave increase in frequency. A baffle will act as a half-space baffle until it reaches about ka=2, where it makes a transistion (45 degrees on log/log graph) to 360 degrees at ka=1. Half space radiation is about 160 degrees (-6db) in real world situations instead of the 180 degrees predicted theoretically. Any loudspeaker in a large baffle is not affected by that baffle at high frequencies where the free-air beamwidth is smaller than 160 degrees or so.
Old 1st January 2010, 07:48 PM   #8
gedlee's Avatar
Dan
Hi Dan
This is audio, logic need not apply.
Old 1st January 2010, 07:55 PM   #9
Key is offline Key  United States
Well my guess would be feedback rejection in live sound applications.
Old 1st January 2010, 08:21 PM   #10
dantheman's Avatar
Hi Dan
That's funny. I've debated audio nuts and gurus that claim just that point with me--even a manufacturer! Yet they have literature and/or design criteria proclaiming their products' and/or builds' superiority. "Just don't make sense."--Ross Perot
LineSource, thank you for that information! It is useful. I think I actually understand it. hahaha
Dan
My Blog
My Music Recordings
75 degree waveguide, any good reason?Hide this!Advertise here!
Results of waveguide "measurements" not so good ... paulspencer Multi-Way 15 2nd January 2010 04:52 AM
Electronics Degree ramalamafafafa Parts 6 7th August 2008 12:27 PM
90 degree tonearm connectors johnandchris Parts 0 16th March 2008 02:25 PM
360 degree phase switch Puffin Everything Else 4 10th April 2006 07:50 PM
A good reason to buy good parts jteef Parts 3 7th February 2003 10:33 PM
Copyright ©1999-2017 diyAudio
