Mark K's er18dxt
Mark K's er18dxt
Old 5th March 2013, 04:41 PM   #101
5th element is offline 5th element  United Kingdom
5th element's Avatar
Heavily stuffing a ported enclosure, with stuffing around the port will reduce the degree to which the port acts. If the end of the port (the end inside the cabinet) is free of any side walls or stuffing then it will work in an optimum fashion.
Stuffing a cabinet alone, be it ported, sealed, or whatever, will increase the effective volume of the cabinet and will alter the tuning frequency. I don't think you can really have too much stuffing unless it is interfering with a port or similar in a detrimental way. I had experimented briefly with stuffing small cabinets with huge amounts of stuffing, ie rolling the stuff up and literally squashing it down inside and the more stuffing I added the more volume the cabinet appeared to have. I think you'd really have to compact and squash down stuffing incredibly tightly to actually end up with a situation where the addition of more stuffing actually lowers the cabinet volume.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 5th March 2013, 04:47 PM   #102
voxxonline is offline voxxonline  United Kingdom
voxxonline's Avatar
Mark K's er18dxt
Can it affect high frequencies ?
Thank you for advice, I ll play with polyfill.
How to find time to finish my projects ?
Old 5th March 2013, 07:14 PM   #103
454Casull is offline 454Casull  Canada
http://www.nousaine.com/pdfs/Box%20Stuffing.pdf
Old 5th March 2013, 07:32 PM   #104
voxxonline's Avatar
Mark K's er18dxt
THX for an article link !
Old 5th March 2013, 08:28 PM   #105
Interesting article, it would appear that the smaller the box, the greater the stuffing density you can get away with. This might explain why I didn't appear to get negative going results with my very small boxes, which are less than 100cm².
Old 5th March 2013, 10:02 PM   #106
PeteMcK is offline PeteMcK
re:"I have stuffed HEAVILY boxes with filler. I had nothing to loose but gained a lot more bass" - good result, but shows the box was too small to start with.... (&/or tuning too low)
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 7th March 2013, 06:50 PM   #107
voxxonline's Avatar
Mark K's er18dxt
Tandata, stuffing works. I will play next week a bit more with stuffing, just to see if reducing amount of polyfill before port will result in better high frequencies. I think I can release more of it. Anyway- my old arcam is the limiting factor.
PeteMck, indeed I have just a bit deeper enclosure and port was to specifications, and maybe it was the reason I had no proper bass.
Old 7th March 2013, 09:40 PM   #108
Here's another.
Volume filling a reflex box
In short, it is recommended, but don't put too much.
Old 7th March 2013, 09:46 PM   #109
voxxonline's Avatar
Mark K's er18dxt
I think I should try to stuff more behind brace around port, keeping port open towards tweeter until middle brace- Bigger density there.
And before brace from drivers side use less stuffing but covering port ...
Old 7th March 2013, 10:03 PM   #110
voxxonline's Avatar
Mark K's er18dxt
Apparently I made right decision using 3 dowels on every side of every joint, plus dowels for the brace ! I did not use any sound deadening sheets (once suggested to me), only damping sheets from europe audio.
Silicone along corners.
As well front and back baffles (25mm thickness, walls are 18mm) recessed (flush mounted ?) into enclosure.
Hopefully it will reduce resonances.
Weight is significant
Mark K's er18dxtHide this!Advertise here!
Murray the K's Disco on Wheels diamondzzzz Introductions 3 25th June 2012 01:33 AM
Invitation to audition John K's OB NaO Speakers in Sydney 9/11/2008 HiFiNutNut Multi-Way 38 11th November 2008 08:43 AM
Amp5 and John K's Seas L15RLYP / 27TFFC System? kidproquo Multi-Way 7 3rd February 2006 04:40 PM
John K's Seas Design, Questions demon2091tb Multi-Way 13 7th December 2005 01:52 PM
Anyone know where i can find John K's P13/D27 project dvdwmth Multi-Way 2 3rd June 2004 10:36 PM
