I'm looking for suggestions for dipole tweeters, the Linaeums are thin on the ground and the Beyma TPL-150 is way above my budget. Anyone used Vifa D25AG77 before ? Anyone know if I can get away with tweeters back to back? Cheers Happy New Year ! Last edited by firestorm; 29th December 2009 at 11:14 PM. |
#2 |
Fast, fun, Inexpensive OB project
Mounting driver's back to back doesn't technically result in a dipole speaker because of the separation distance between the two drivers. Of course real-world it might not matter much, or perhaps more correctly the baffle shape/size you use will likely have a much greater impact on the results then a minute difference in distance (..assuming it actually is quit small).
perspective is everything |
#3 |
Hi Scott,
thanks for the link, very informative ! Happy New Year ! |
#4 |
Tangband W2-800SL
With 18ohm series resistor and 3.3-4.2uf it sounds quite nice Theres indication that a paralel 15ohm will improve And maybe a paralel inductor and resistor But at the moment it plays with just the series components I know, 18ohm in series seems strange, but it really works Other values may be better, I just threw it together in an hour Been listening to it fore a week, and nothing to complain about At this price I doubt you will find any better Last edited by tinitus; 30th December 2009 at 12:02 AM. |
#5 |
I would love to find more (small) affordable dipole tweeters.
I currently use the Neo3PDR, and have no complaints. It has excellent polar response, and hasn't blown while listening loud (although I'm still waiting for PE to get them back in stock since blowing them when switching amps live - if you're going active with your crossover, don't be like me, use protection!). They are affordable too. Some of the AMTs look really nice, but are way too expensive. I experimented with small, back to back tweeters here. They worked surprisingly badly.
double complete rainbow all the way!! |
#6 |
A few dipole speakers are taking the rear cover off of compression drivers to generate dipole radiation. Coaxial speakers with integrated compression drivers are also using the open dome back for dipole radiation. Few seem to be putting a horn on both the front and rear of the dipole compression driver
Has anyone experimented with using a compression driver with the rear cover removed for dipole operation? Are any specific compression drivers constructed to operate safely without their rear cover? |
#7 |
I'm also interested in this topic. Having used the Neo3PDR with great results I want a tweeter that can be crossed at 1kHz or lower. I've been thinking about the M&D DM-4 driver wich is available at $250 per pair. I know about Zaph's measurements and I don't think they look as bad as he thinks they do.
#8 |
Gainphile has had mixed results with soft domes back-to-back, so I might bite the bullet and jump to ribbons like the Neo3, where ScottG has provided a link to a very interesting article about adding a horn/waveguide to the Neo 3.
The B&G Neo3/8 look like possible candidates, the Founteks are easier to source, but are not dipole or easily converted into dipoles. Whats the best place to get the B&G's ? |
#9 |
#10 |
Neo3 aren't ribbons but magnetostats. If your crossover is at 2kHz or over Neo3PDR is all you need IMHO. Parts Express sells them and I'm sure there's sources for them in Europe too.
| FS: Linaeum/Tandy Dipole Tweeters | rabidlistener | Swap Meet | 3 | 27th July 2007 10:16 AM |
| FS: 1 pair of aura / linaeum dipole ribbon tweeters | zobsky | Swap Meet | 9 | 13th September 2006 09:46 PM |
| Set of 4 Optimus Linaeum Dipole Tweeters on Ebay | The Paulinator | Swap Meet | 1 | 13th July 2005 06:30 AM |
| FS: New Optimus Linaeum Dipole Tweeters from Radio Shack (pair) | shawnharper | Swap Meet | 1 | 30th November 2004 08:48 PM |
| Page generated in 0.09996 seconds (80.08% PHP - 19.92% MySQL) with 11 queries |
