Old 28th December 2009, 03:49 PM   #1
Default Jordan Mini Monitors
I am getting ready to build the Jordan Mini monitors as designed by Dr. Jim Griffin. I am unsure of the measurements of the enclosure. The write up i found said 12"x7.5"x 11.75". Are these inside or outside measurements? What is the volume desired? The port is listed as 1.5" diameter but I can't find how long it should be. I would appreciate your help. Howard
Old 28th December 2009, 07:53 PM   #2
On my prototypes I'm using Parts Express #260-388 port tubes. I use the non-adjustable section only which is 4 5/16" long and 1 3/8" inside diameter. The dimensions you gave are external size with the 7.5" width value being critical. The internal volume can vary between 7-9 liters (0.25 cu. ft. -0.3 cu. ft).
Old 28th December 2009, 07:57 PM   #3
brianco is offline brianco  Ireland
brianco's Avatar
Location: Scottish Borders - Kelso; on the famous Tweed River!
<http://www.ejjordan.co.uk/diy/index.html>
is the DIY section of Jordan's site.
These are amazing speakers in my estimation. I was given a demo in the home of the designer and was flabbergasted at the sound which he was getting. Bandor units are similar and Doreen Bandor and the Jordan boss were at one time married to each other!
DIY Mini monitors hughes123 Multi-Way 7 17th February 2009 02:56 PM
full range mini monitors airframe Full Range 16 19th July 2006 03:24 PM
Coral Mini Monitors kerryvh Full Range 11 24th February 2005 09:42 PM
Jordan monitors - pics and specs IanHarvey Full Range 16 26th February 2004 02:32 PM
Mini-Monitors for PC and Mixing stealthgear808 Multi-Way 3 1st July 2002 02:52 AM
Page generated in 0.07707 seconds (69.69% PHP - 30.31% MySQL) with 10 queries
