Any ideas on a good articulate 6 1/2 or 7" driver for a 2 way to be paired with Seas 27TDFCs? I'm looking to change out my current ones cause they are just not cutting it. 2 woofers in each cabinet.
#2 |
Have you checked out Zaph's web site? Zaph|Audio . Also, see Mark K's web site Measurements That ought to give you a nice short list.
What driver are you currently using? Note that much of what makes a successful loudspeaker is due to correct implementation, not only good drivers...
Shaun Onverwacht |||||||||| DON'T PANIC |||||||||| |
#3 |
I have used Seas ER18RNX in a MTM configuration. These are best speakers which I have had. I have also used Seas Excel and Scan Speak Revelators.
Seas ER18RNX / 27TDFC MTM |
#4 |
The Seas ER18RNX is an excellent driver. Still working on mine. Quite hot on the mids. Needs quite a few dB in BSC to tame it.
Check out the Dayton RS180. I'm using this with the 27TDFC in a 2-way DCR. For articulation, use this Dayton RS series. How are your woofers arranged? MTM, MMT or 2.5?
AmpsLab.com |
#5 |
What I have now are zetag woofers arranged TMM. Not terrible by any means but just doesn't have the openness/articulation i'm looking for.
#6 |
Do you have a schematic of the crossover network and the datasheet of the zetags?
AmpsLab.com |
#7 |
ScanSpeak or Usher. If you have 2, might think about going down a size.
I found the Dayton RS series very difficult to use due to their break up regions. Others love them. I agree with there Michael is going, don't give up on the drivers until you reconsider the crossover. |
#8 |
These metal cones can be a pain. You'll need to keep the cone breakup well away from your crosspoint. This is where a zobel network helps tremendously.
Looking at the Dayton 8", the RS225s-8, I think the highest I can cross is up to 1K. This is 3 octaves away from 8K, which is where the peaks are. Haven't quite decided whether to buy the RS225 yet. BR box is a bit too big for my liking. Does make a good 40L Bandpass Sub though.
AmpsLab.com |
#9 |
I have tried 2 different x-overs with these 1 is attached done by PE tech. Specs on the drivers are included. The other x-over I used I don't have sheet on.
#10 |
Soft Dome |
| Some 8"/5"/4" driver DIY...... India | sumit | Full Range | 8 | 18th November 2009 10:26 AM |
| FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) | theAnonymous1 | Swap Meet | 0 | 24th April 2007 12:09 AM |
| Is it worth buying cheapy 15" driver or expensive 12"? | VEC7OR | Subwoofers | 7 | 26th February 2005 10:09 PM |
| Best Value 8",10" or 12" Driver | cj.9 | Subwoofers | 15 | 8th December 2004 10:28 AM |
| HT: scale 10" sub cabinet for 12" driver? | bbaker6212 | Multi-Way | 9 | 8th May 2003 06:54 PM |
| Page generated in 0.09636 seconds (76.02% PHP - 23.98% MySQL) with 11 queries |
