Old 28th May 2003, 12:52 PM   #1
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Default Series crossover question
I found this schematic and was thinking about using it for my Grand Slamm clones. However, I'm using two C-79 (insted of one), tweeter stays the same and no woofer (but still high-pass on a midrange). What kind of changes I would have to make to this design to be able to use it with my setup?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 28th May 2003, 01:00 PM   #2
Bricolo is offline Bricolo  France
Bricolo's Avatar
I'd say: supress C2-5 and L2
and you'll have to re calculate the L pad, with values for 2 C-79, and also another attenuation since you'll have +3dB with 2 mids
Old 28th May 2003, 01:05 PM   #3
Bricolo's Avatar
I think I misunderstood
You want to make them 2.5 way, aren't you?
So, yes, it would work
simply replace the woofer with the second c-79
if the C-79 are more efficient than the tweeter, you'll also have to place an L pad on the lower C-79
I'm not sure about the L and C values, but I think you could keep the same. But to be sure, you'd better wait for a specialist's advice
Old 28th May 2003, 01:24 PM   #4
I think I want it two way, where midranges are in parallell. My main concern is L2, because I'm not sure if it's in midrange or woofer circuit.
www.audiosector.com
Old 28th May 2003, 01:33 PM   #5
Bricolo's Avatar
L2 is on the midrange
the midrange has C1 and L2 around it-> a high pass and a low pass
the woofer has C1 and C2-5: two low pass
if you put out L2 and C2-5, and change the L pad's value, you'll have a 2 way system, with the 2 C-79 producing the same frequency range as the C-79+C-92 did
but by doing this, you change the XO orders (you'll have a 1st order low pass, instead of a 1st order bandpass+2nd order low pass)
if I were you, I'll simply replace the C-92 with a C-79, and change the L pad
maybe even supressing the L pad, since the C-92 is the only that has'nt one I think it's the less efficient driver. If the tweeter and the midbass have the same efficiency, don't keep the L pad nor the resistor on the tweeter
Old 28th May 2003, 01:37 PM   #6
uli is offline uli  Austria
Default Re: Series crossover question
Hi Peter,
Look here: Seies
I built a MAXX Clone with a Xover very similar to the "Proteus"
works fine
Uli
'Jazz is not dead, it just smells funny' F.Zappa
Old 29th May 2003, 06:02 AM   #7
frugal-phile(tm)
planet10's Avatar
Peter,
if you ignore the resistors (which are there to pad the various drivers), what you have is 2 2-way series X-overs that are ganged. If you remove the woofer, you also need to remove L2 and C2. You will not get any high pass on the midrange with a series XO (you will have to put it in front of the amp).
I suggest you go to Andy Graddon's site where he has a stash of info on series XOs. There is also a SS there for calculating values...
Everything depends on everything else in a series XO, and you will want to toss the L-Pad on the mids which will throw off the padding on the tweeter. That will change the effective tweeter impedance.... you might as well start from scratch
On the positive side -- if that XO works -- it means that you should be able to come up with a series XO for your config -- probably just a single L, C and maybe an R for the tweeter -- how close are the sensitivities of the T and a pr of the mids?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 29th May 2003, 06:13 AM   #8
Thanks Dave,
That's the answer I was looking foras this makes sense. I don't remember exactly the sensitivities of the drivers, but checking the current versions it looks like mids might be 1dB less efficient than tweeter. I think I saw Andy Graddon's site before, but lost the link. The one I just found using search is not working.
www.audiosector.com
Old 29th May 2003, 06:33 AM   #9
frugal-phile(tm)
planet10's Avatar
Andy just recently moved his site... he did post a link here. probably his most recent post... yep
Due to popular request.......
diyAudio Forums - Due to popular request.......
he hasn't got it all put together, but i sucked most of it before he moved it -- just in case... so if need be i could mail bits to you.
dave
Old 29th May 2003, 06:43 AM   #10
frugal-phile(tm)
planet10's Avatar
Then you will probably just need a small series R in the tweeter circuit, plus the L & C.
dave
Series Crossover george a Multi-Way 117 9th March 2012 07:24 AM
Parallel/Series crossover wiring question cerupcat Full Range 7 21st November 2011 05:25 AM
What kind of series crossover is this Ralph Johnsen Multi-Way 10 10th February 2009 10:04 PM
AR series crossover pei Multi-Way 3 9th December 2006 01:00 PM
Series Crossover!!!!!! and some other stuff bostarob Multi-Way 7 13th July 2002 02:37 PM
Page generated in 0.11194 seconds (79.66% PHP - 20.34% MySQL) with 11 queries
