Hi all.
I need your help. I want to build a MTM TL speaker, with Lyeco 6,5" drivers, 2 piece/box. What kind of box type you would recommend this drivers? Classic TL(tight), MLTL, or TQWT. Can anyone help me, the box/plan design? Thank you, your help. Here is the drivers parameter. |
#2 |
Hello
Where did you get the Lyeco Speaker? I am searching for a vendor.
kind regards Christian |
#3 |
Dear Sonobox.
5 years before, I had an onetime opportunity onto the shopping. The firm, closed already where I bought the drivers. |
#4 |
had a quick play with these in Unibox; as a BR, even though Unibox recommends a large enclosure (~120 L) for 2 drivers, 45L tuned to 45Hz gives ~ 3db hump in the low region which could be used as BSC; so depends on how big a box you want, but I'd guess MLTL would maximise the bass output, but you might run out of excursion (actually the FR makes me think they'd be good as mids paired with a good woofer...)
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
| Enclosures for Tangband and Lyeco Drivers | AlejandroR | Full Range | 6 | 11th December 2009 08:56 PM |
| MTM Port placement between drivers? | tresch | Multi-Way | 4 | 2nd June 2009 12:25 AM |
| Where to buy Lyeco fullrange drivers??? | kyrie48 | Full Range | 1 | 22nd November 2008 02:29 AM |
| Where to buy Lyeco/Dynavox drivers?? | kyrie48 | Multi-Way | 0 | 19th November 2008 04:19 PM |
| Page generated in 0.06864 seconds (68.40% PHP - 31.60% MySQL) with 11 queries |
