Any reccomendations for 18" speakers for hifi? Everything I've found is for PA useage, I'm looking for something accurate with a high efficiency like 98dB+. Anything considered, I was looking at neodynium as quite feasible
#2 |
Oh, no! HiFi vs PA again.
#3 |
The JBL 2245H was used in hifi for subs, and in studio monitors (4345) up to 300Hz.
It is 95dB/1W/1m |
#4 |
Freedom of choice ...
Boutique haut parleurs et audio DIY |
#5 |
PA drivers are generally designed for high SPL and this usually requires a high Fs as part of the design compromise.
Home reproduction requires replay of lots of different music/sounds/voices and this generally requires a lower Fs. There are few 18inch drivers with Fs below 30Hz and those that are, are generally of lower sensitivity, due to the heavy MMS that makes the extreme LF response possible.
regards Andrew T. |
#6 |
#7 | |
regards Andrew T. |
#8 |
Works great for a subwoofer (can easily be EQed to give a 15Hz cutoff with enough SPL to dislodge plaster), but it really doesn't do well at 250Hz and higher.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#9 |
I use an Eminence Sigma Pro.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#10 |
Not sure I understand your question
Coil winding depth/length is 22mm Pole plate is 10.5mm Linear Xmax is set to 9.25mm (P-P) Do you mean the 2mm remaining (22 - 10.5 = 11.5mm) ? They seem to be conservative with Xmax specs on many of their drivers I dont know, maybe its due to magnet field bending a bit beyond gap, which kind of increase the gap, thus shorter linear Xmax edit, the PD 15" seems the opposite with 10.5mm Xmax, (25 - 9 = 16mm), 8mm+/- over 10.5mm+/- This PD with great Xmax seems a nice choise to play with EQ Last edited by tinitus; 24th December 2009 at 02:32 PM. |
| WTB 15" or 18" high qt. drivers | homemade | Swap Meet | 13 | 14th June 2010 07:15 PM |
| who makes 18" x 12" x horn 3-w box??? | mastadon | Full Range | 2 | 29th October 2009 08:31 PM |
| AES E-Library: "An 18-Bit Delta-Sigma D/A Processor System..." | aparatusonitus | Digital Line Level | 4 | 7th May 2009 10:01 PM |
| Can I multiply an 18" folded horn cab by 0.8 for a 15"? | Optical | Subwoofers | 7 | 31st October 2004 04:37 AM |
| Page generated in 0.09811 seconds (75.58% PHP - 24.42% MySQL) with 11 queries |
