Old 24th December 2009, 03:19 AM   #1
gary h is offline gary h  United States
Default 4-way wiring question
Hi all,
I'm actively eq-ing a pair of WWTM floorstanders with one amp per driver. That means running 4 +/- pairs of cable to each.
Is there any reason I couldn't sum the negative rail and send 5 leads per side instead of 8 (1 + per driver and 1 - for the four)?
Come to think of it, could I also do this between the eq and amps and use a 1 foot DIN connector per channel? My intuition tells me that I would be creating an impedance imbalance somehow that might introduce noise. Maybe the DIN connectors are not suitably insulated either.
Thoughts?
thanks
gary
Old 24th December 2009, 11:03 PM   #2
Originally Posted by gary h View Post
Hi all,
I wouldn't do that since current is going to change the ground reference at the speaker which is effectively introducing cross-talk which can have audible effects if it stimulates driver resonances.
I used an 8-pole Speakon at the speaker, 8-conductor cable, and choose pairs with minimum cross-talk between tweeter and midrange so the tweeter signal doesn't stimulate the midrange cone resonances.
Old 26th December 2009, 02:48 AM   #3
Thanks Drew.
I've admired the Speakon gear, it would probably be the most expensive component in my project. I'll take your advice, I will probably use 16 gauge lamp cord for each run instead of the 12 gauge stuff I'm using now to connect to the speakers' passive crossover (the run is about 10')
gary
Sub Wiring Question jthunder Subwoofers 1 30th January 2007 12:25 AM
Wiring question LizardBrain Multi-Way 4 26th March 2006 03:46 PM
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
Another wiring question. Prof Chip Amps 1 3rd July 2003 07:39 AM
A wiring question. G Tubes / Valves 4 29th December 2002 01:08 PM
Page generated in 0.07215 seconds (71.78% PHP - 28.22% MySQL) with 11 queries
