Old 22nd December 2009, 08:35 PM   #1
form109 is offline form109  United States
Default Two Old 6.5" Midbass Drivers...what to do with them?
today,i went to the Flea Market...(Again)...and picked up a Pair of 6.5" woofers or Midbass's that were just Floting Around...both of them seem...well...eh...intreasting...Diffrent they are...not being a Matched Pair,has anybody seen either of these woofers before?
Old 22nd December 2009, 09:03 PM   #2
The Woofer to the Far Left (Picture 1 From the Left) has Specs on a Paper Label on the Magnet 40-3K,15/30 Watts,8 Ohms
The Woofer Next to it (Picture 2 From the Left) only has a 4 Ohm Rating as far as specs go,this woofer has a Higher mechanical Excursion than the Previous woofer.
Old 22nd December 2009, 09:12 PM   #3
I have a shelf full of similar drivers, measuring them, usually they have too high a Q to be useful in a BR box... save them for experiments or if you get enough an OB...???
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 23rd December 2009, 04:38 AM   #4
Well these were the Only i saw of Each..
Old 23rd December 2009, 03:04 PM   #5
Hello form109, the driver with the oval shaped cutouts in the frame appears to be something from Radio Shack, this is a S.W.A.G based upon the label on the back of the magnet. It's pretty much the same as labels on the rest of the Radio Shack drivers. I went to Radio Shack's website and did a quick look around, they don't appear to have any info on this driver. Probably best if you can do some reading on testing drivers, then start to measure them. You will get the best result this way when you use them.
Peace,
Dave
Old 23rd December 2009, 03:21 PM   #6
Speakerholic
Cal Weldon's Avatar
Gotta love the truth in advertising though - the pic on the right
LoEff
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 24th December 2009, 01:23 AM   #7
LoEff
Never heard of LoEff....seems like it would be the brand but a Search didnt give me any Usable Results.
Peace,
Dave
i dont really have any Way to test them other than Running Frequency Sweeps through them...and what is SWAG?
Old 24th December 2009, 01:37 AM   #8
Hello form109, by LoEff, Cal is being humorous. He means Low Efficiency.
As far as testing drivers goes, frequency sweeps are a good thing, especially if you can measure the impedance of the driver as you are doing the frequency sweep. It will vary over the audio band. If you do some poking around on this site, and the web in general, you will find information about how to test the impedance relative to frequency. There are other measurements also, but it would be best for you to hunt around for the info, others have probably explained it better than I would.
S.W.A.G -
Scientific
Wild
A**
Guess
Peace,
Dave
Old 24th December 2009, 02:13 AM   #9
S.W.A.G -
Scientific
Wild
A**
Guess
Peace,
Dave
Dave...the Label says the Speaker has a FR of 40-3 K...would this only be a Useable FR since the Driver responds to Frequincies outside of that Band?
Does Anyone have a Clue about the Other one?
and Funny Cal
but i'd say its a solid 88 DB.
Old 24th December 2009, 02:14 PM   #10
Hello form109, you are correct in your assumption as to the frequency response shown. But one thing I have learned around this forum, from those with much more experience than I, is that an actual driver can vary quite a bit from the published specs. So if you can actually get measurements of the particular driver(s) you will end up with a much more accurate design.
Peace,
Dave
P.S. not sure about the other driver, going to have to take another look at the pics.
B&C 10NW64-8 10" Midbass Drivers For Sale - 1 Pair opc Swap Meet 3 5th May 2009 04:35 AM
2.5 way with different midbass drivers pjpoes Multi-Way 11 26th June 2008 08:06 PM
7" midbass and 1" tweeter for 60$ and 30$, what about SEAS? Bricolo Multi-Way 23 20th July 2007 04:35 PM
2 way with large midbass drivers? FE3T Multi-Way 0 4th November 2006 11:01 AM
high efficiency 10-12" midbass drivers Puggie Multi-Way 3 19th August 2005 03:35 PM
Page generated in 0.10441 seconds (86.90% PHP - 13.10% MySQL) with 11 queries
