Old 22nd December 2009, 03:50 PM   #1
Default Crossover for Vifa XT25SC-90/04
Hi, I'm planning to build a 3 way using the Vifa XT25SC-90/04 as a tweeter.
Reasons for this tweeter are a decent performance (as per Zaph), a small flange and availability here in Europe.
What bother me is the strong impedance peak at resonance (837 Hz). I'm planning to cross it at around 3K5 with a second order filter (maybe 6.8 uF + 0.15 mH). It is enough? or do I have to flatten (how?) the impedance peak?
TIA, Ralf
Old 22nd December 2009, 07:13 PM   #2
Hi Ralf
The Vifa XT25SC-90/04 is a good tweeter. The high resonance is a limitation though. I cross my XT25 at 3K5 at 18dB. Very clean, no problem. Can't go lower than that unless I use a LCR to damp the Q.
I just finished a 2-way monitor using this XT25 with Zaph ZA14. Details are in my website.
Mike
AmpsLab.com
Old 23rd December 2009, 12:55 PM   #3
Hi Mike,
for LCR you mean this?
Are there better calculators?
Thanks, Ralf
Old 23rd December 2009, 02:31 PM   #4
Yes, that's the one. A Series Notch Filter. It's quite effective to dampen tweeter resonance.
I think you will be alright with 12dB at 3K5. I don't use 12dB for tweeters because of phasing issues with my woofer which is at 12dB. So my tweeter is either 18dB or 24dB.
FRD has very good software (free). Download Jeff Bagby Passive Crossover Design Calculator. Excellent for speaker design. Series Notch is on the 3rd page.
AmpsLab.com
Old 31st December 2009, 01:13 PM   #5
Mike,
I forgot to thank you for the info.
I will give the Passive Crossover Design Calculator a try, even if I already use the Passive Crossover Designer from the same author.
Ralf
XO for Vifa PL18WO-08-09 and Vifa XT25TG30-04 MTM knightat83 Multi-Way 6 24th January 2009 08:51 AM
Vifa DQ25SC16-04 design kamppi Multi-Way 2 12th October 2008 06:42 AM
WTB : VIFA MG27tg29-04 khjen Swap Meet 0 24th March 2008 07:39 AM
FS: 4 (qty) Vifa PL11WG-04 Woofers for $90 USD shipped to Canada or Lower 48 dtm1962 Swap Meet 3 6th November 2006 04:01 PM
Vifa XT25 (regular) vs. XT25SC (shielded version with Nd magnets) capslock Multi-Way 3 10th January 2003 01:01 AM
Page generated in 0.09728 seconds (74.78% PHP - 25.22% MySQL) with 10 queries
