hello i've been checking out what few threads i could find on basket damping however none so far includes any elaboration of the theory. i'd like to know how 'extreme' i could take the process to before it becomes harmful. currently i'm listening to a pair of tangband w4 1337 that i damped the magnets of with a layer of vinyl sound dampening sheet and an inch foam attached to the backs of them. tangband's baskets have grooves molded into the legs- should i fill them up also? i will be using the drivers in a dipole design- jim holtz's statements to be exact.
#2 |
Just be careful not to block the air flow behind the driver, or make it any less than it is
Just smoothe out the sharp edges And I wouldnt use plastic stuff that could get statically loaded, but thats just me Soft clay stuff that doesnt dry out has always been a good material Actually I never thought about it, but those metal shielding cap used on many drivers may actually ring like a bell Pretty awful to think of Last edited by tinitus; 22nd December 2009 at 10:10 AM. |
#3 |
the 'vinyl' sheet is actually a rubber/silica composite and doesn't act anywhere as flexible as the product pics from PE might i add. static isn't a problem with this material. well recommended imho.
#4 | |
where do you find these ideas ? You are certainly a discerning listener ! I do not use materials which can carry high Static charge of the opposite Polarity to other materials inside an enclosure. Research "Triboelectric" for static characteristics of various materials. Metal sheilding caps - well the one over the back of the magnet in my KEF iQ3 is open hollow behind the cone's back radiation, and I reckon some reflections and resonance will occur in there, but I'm not going to install plastic foam there as the inevitable heat from the magnet when driver is used will cause deterioration of the foam over time. I may install something that has close to the same triboelectric characteristic as the plastic rear of the cone.
Alan |
#5 |
how thick of a foam can i attach behind the magnet? can it be of same thickness as the magnet? thats how mine is right now and it looks a bit of an overkill.. but naturally thats only my guess xP
| Magnet driver mount | inrank | Full Range | 8 | 11th August 2009 08:48 PM |
| Basket, magnet & frame damping: How to? | gnugear | Full Range | 24 | 26th March 2008 10:05 AM |
| FR125s frame/magnet damping | Foxx510 | Full Range | 3 | 6th August 2007 02:02 AM |
| 12" driver square magnet | bickeler | Swap Meet | 1 | 25th April 2006 11:46 AM |
| Page generated in 0.08121 seconds (81.01% PHP - 18.99% MySQL) with 10 queries |
