Hi People,
I'm going to build 2 monitor speakers (bookshelff type). Containing this speakers: Fountek NeoCD3.0M RND BLK Specs: Click here ![]() And: HiVi research F5 5" bass-midrange - Specs: click here ![]() I started a few weeks ago with budget speakers from Visaton and used boxsim to create a filter. But all the specs from the Vistaton filters are available for boxsim, is there any way I can do the same trick with other software? With boxsim I created something like this (wasn't final) ![]() ![]() How can I create a filter for this set? I will need a 3rd order for the tweeter. I know you can just create a filter with tools like here: 2-Way Crossover Designer / Calculator But would really like to see a graph like in boxsim, is there any way to do that? Thanks in advance for your support! (ps. I still a newbie, don't make the replies to hard :P) |
#2 |
I use LSP CAD but Boxsim is good too and free. What is interesting in LSP Cad is that the speaker can be electronically simulated. So you can ether hear over headphones or use a soundcard with multiple amps. After you decided on the sound you can then build the spaeker physically. It saves me lots of time.
#3 |
usually you create filters after a target.
| My first "from scratch" design, SE KT88.......... | cadaverdog | Tubes / Valves | 9 | 8th April 2008 06:39 AM |
| Active crossover from scratch. | tade | Parts | 2 | 31st October 2005 05:21 AM |
| Design from scratch (LM3886) | VEC7OR | Chip Amps | 25 | 30th September 2004 01:16 PM |
| Loudspeaker project from scratch - driver construction, cabinet, & crossover | UncleJessie | Multi-Way | 19 | 20th April 2003 04:26 AM |
| How to design an amp from scratch... | Bakmeel | Solid State | 1 | 26th March 2002 01:10 AM |
| Page generated in 0.07788 seconds (71.49% PHP - 28.51% MySQL) with 10 queries |
