DIY Tannoy GRF's - Long with lots of pics
Old 21st December 2009, 11:43 PM   #1
Speedysteve7 is offline Speedysteve7  United Kingdom
Speedysteve7's Avatar
Default DIY Tannoy GRF's - Long with lots of pics
I recently built some Tannoy rect GRF replica's out of 21 / 24mm birch ply.
I am happy with the result and thought to share it with you guys.
I be used my Tannoy Berkeley HPD 3828 15" drivers.
They are a copy of plans found on T'internet but to the same dims as a friends with golds and made of 18mm ply throughout (which I've heard).
Here is the cutting sheet plan.
Idea was to make the round front panel cut compatible for both 3828's and Golds / Reds.
A friend kindly put the data into a horn calc prog and things came out very much the same as for his 15" Monitor Golds (see below).
HPD params
HPD response
Monitor Golds params
Monitor Golds response
Apparently the comb filtering is normal. So it was agreen light on HPD's working on paper.
Next the ply arrived on palette - very well packed.
Unpacking revealed all parts accounted for.
All the machine faces are tip top perfect.
I put all parts for one speaker on the scales - yikes ~55kgs. Gonna be heavy things with plinths and drivers etc. I think castors may be a good idea
I will need my trolley and a ramp to get them out of the garage from then on it's all flat to the lounge - best done when wife is not around. Honey I grew the speakers.
Pics
Palette - with protective sheet of waste ply removed.
Old 21st December 2009, 11:47 PM   #2
More pics
2 Speakers worth - doesn't look like 110kgs there but there is!
So the build started
Lining it up
Driver mounting plate
Front panel in
Old 22nd December 2009, 10:24 AM   #3
next 10 pics
Castors from wardrode base that had been in the loft for 11 years
A few more evenings and the first one was almost ready
Here's how it would have looked using the Berkeley grilles
Boy the castors were a good idea!
The one on the right is rubbed down and two thin coats of polyurethane
They are now named Bertha & Big Bob by the family?!
The felt took a few says to arrive so I had time to cut the slots for the crossover panels and put the terminal posts on the backs.
Just 3 internal horn baffle and 2 reflector pieces in each speaker to go and transplanting the drivers etc over.
Pic of felting I used and blind nut fitting (re-used from Berkeleys).
First one in place
Wife likes the colour at least...
2nd one ready
All together
More to follow
Old 22nd December 2009, 02:12 PM   #4
So how do they play.
I chose Ry Cooder Paradise and Lunch to start with - fantastic slide guitar esp Fool for a cigarette.
On to Jan Johansson (Swedish Jazz pianist - died 1968 car crash :-(.
Wonderful european / different take on jazz.
Well, what can I say about these speakers then.
Firstly they were a bit of a shock. Different tonal balance and very open.
Loads of deeeeeeep bass. Not boomy or out of control just deeper than
the Berkeleys could muster.
Mid and treble they are quite laid back. Went to level one on the treble
on crossover - all speakers should have this facility
There is plently of detail and depth. Effortless and instruments sound
more like instruments. That timbre / resonating clarity you should get
with music.
The Berkeleys are good - these cabs just take what the drivers are
capable of to another level.
The more I listen the more I like them and the improvement is apparent.
These 3828 HPD drivers are very good - clearer in the mid and treble
than I heard Golds that are a bit warmer and cuddly.
Taking almost as long as one speaker it was speakers covers time.
Wife chose the cloth colour. She does not like the drivers showing
really
First the frame surrounds (wood came from Wickes clearance bin at 0.99p)
Next some stretching & stapling
One done
Then to mount them. I ordered Wilmslow speaker grill lugs
And the result
Next some GRF badges to finish them off...
Listening to them some more and more stuff- amazingly good speakers.
These are keepers!
Chosen badges arrived and duly fitted. Looks almost complete now.
Finally I made some castor hiding plinths and varnished them. On carpet
(my intended flooring for the music room - another project) they just
brush surface allowing the castors to do the wheeling for convenience
but not leaving a noticeable gap.
Well that was a great fun project - I am happy to discuss making a pair
for anyone interested.
Could also be conventional curved top and base style too - I like the
more modern mitre finish in our room though.
Old 22nd December 2009, 02:25 PM   #5
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 22nd December 2009, 02:52 PM   #6
DaveCan is offline DaveCan  Canada
DaveCan's Avatar
Wow really nice build and retro/ new look, great job!!
Old 22nd December 2009, 03:40 PM   #7
c2cthomas is offline c2cthomas  United States
c2cthomas's Avatar
DIY audio can be expensive but getting to see things go up in smoke - that's priceless!!!! ..... "whatever - call it brainfart of Mighty ZM"
Old 22nd December 2009, 03:45 PM   #8
oublie is offline oublie  United Kingdom
Nice walk through,
who cut your plywood for you or is this a kit?
Old 22nd December 2009, 04:30 PM   #9
Originally Posted by oublie View Post
Nice walk through,
A company called Avon Ply. They did a really nice job on the mitres and everything was done to 0.1mm accuracy.
As you could see packing was very good - no risk to those fragile mitred edges.
I am currently acquiring wood to build two more sets for fellow 15" Tannoy owners. Both HPD's of the Alnico variety.
They came round to my place a couple of weekends ago and threw all the hard to play stuff (that their Berkeley's and similar cabs to Chatsworths struggled with) at the GRF's and after a while said - "I've got to have a pair of these"
There is so much more information coming out at sub 200hz level it's amazing but they are nicely balanced too.
Old 22nd December 2009, 04:43 PM   #10
AKN is offline AKN  Sweden
No snake oil
AKN's Avatar
DIY Tannoy GRF's - Long with lots of pics Send a message via MSN to AKN
Very nice!
I'm a Tannoy owner myself (3808) so I can sort of imagine how well these sound.
/ Anders
DIY Tannoy GRF's - Long with lots of picsHide this!Advertise here!
Aurasound, Scanspeak Revelator, Seas Excel, Peerless XLS 8 (LOTS of pics) thadman Swap Meet 50 7th August 2008 06:18 AM
New Member with lots of pics.. Ludapower Introductions 34 31st December 2007 10:44 PM
Copyright ©1999-2017 diyAudio
