Old 21st December 2009, 08:07 PM   #1
Default pairing 2 16 ohm horns
I have to two pairs of mid range horns that I would like to combine to make to two mid cabinets. Both sets are 16 0hms, One pair are Cerwin Vega's (forgot model # but they came out of Cerwin Vega V35s) the others are JBL 2461's, I would like to wire one of each together to make one pair of mid cabinets. Any suggestions or ideas would be great, should I wire the two having the total load at 16 or 8 ohms...
16 ohm vs 8 ohm InclinedPlane Full Range 7 29th June 2008 02:00 AM
parallel wiring 16 ohm 4 ohm tobler Subwoofers 3 21st November 2005 04:28 AM
16 ohm drivers? morbo Full Range 24 16th November 2004 04:58 AM
Two 4 ohm woofers in series or two 16 ohm in parallel. Which is better? Cal Weldon Multi-Way 16 21st February 2004 12:31 AM
Matching my 8 ohm amp to 16 ohm speakers. DocJDG Solid State 3 5th December 2001 01:54 PM
Page generated in 0.06138 seconds (65.67% PHP - 34.33% MySQL) with 10 queries
