Old 20th December 2009, 11:29 PM   #1
Default I have the box... so now what???
Hello,
I have some old (MASH PRO 45) 3way compression loudspeakers. I tought that I could replace the old drivers with some new ones and make them sound good on my DENON PMA-655R witch is a 8 Ohm 50W amp.
I looked around the net but I'm not... you know, good with the math.
So here are the internal dimensions:
H 462mm(18.1inch)
W 242mm(9.5inch)
D 165mm(6.4inch)
17L volume
with drivers:
75mm(3inch)
100mm(4inch)
205mm(8inch)
The holes are centered.
And if any of you know of a project with a similar configuration and can point to some drivers and maybe even a crossover...
Well it will be just grate...
If not, I don't mind if you ignore me. But thanx for reading anyway.
Old 22nd December 2009, 02:07 AM   #2
this design will fit that box.... Zaph|Audio - ZA-SR71
(It's usual to select the drivers first, & then design the box)
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 24th December 2009, 08:58 PM   #3
tizeye is offline tizeye  United States
And the question is why?
+1 on select drivers first, then the box, particurally when MDF is only $18! Perhaps salvage other innards from the old box.
I just finished building the SR-71 and very pleased. Altered slightly as I built the crossover rather than ordering the prebuilt kit. Below could be said for virtually and other speaker as well, particurally with the 3 different size holes would rule out all MTM's.
On the old box, the 18.1" (15.2" spec) height and 9.5" (9" spec) width are OK but the 6.4" (10" spec) is way too shallow to support the internal port of the SR-71. Plus you have to create a new from baffle anyway converting from a 3 way to a 2 way. Pick the drivers, then build the box (or select a premade).
Old 25th December 2009, 07:16 PM   #4
The more I look around, the more I see the truth in your words.
And since I'm unable to do any wood work (no tools and no friend with tools), I will have to lean towards a more radical solution; replace the speakers completely.
I fancy B&W 685.
Ill keep this project alive tough.
Aperiodic box for B200. Vent size and box shape? ChuckT Full Range 11 15th October 2006 07:29 AM
Want to re-box several si t amps in one box. How do I hook up to one power supply? ExJxC Class D 7 22nd September 2005 09:27 PM
Box Design/Make me a Box Focal 5WS arnach Car Audio 5 13th December 2004 06:56 AM
High voltage umbilical and connectors / 1 box for PSU 1 box for amplifier in kit88 PTSOUNDLAB Tubes / Valves 30 10th September 2003 07:45 PM
Page generated in 0.08698 seconds (74.86% PHP - 25.14% MySQL) with 10 queries
