My sphere in cube idea for reducing standing waves - Page 3 - diyAudio
Old 13th December 2012, 11:48 PM   #21
pepsi is offline pepsi  United Kingdom
pepsi's Avatar
Originally Posted by LineSource View Post
Thanks for the link!
Old 14th December 2012, 01:57 AM   #22
Originally Posted by pepsi View Post
you cant damp a standing wave because its not moving. you cant hear standing waves. i thought the curved edges of a sphere would 'focus' sound in some way.
Old 14th December 2012, 02:39 AM   #23
Of course there are nice things about a sphere. For instance, the shape is good at resisting deformation from pressure increases while minimizing material and weight. Anything with flat panels can 'blow up' by flexing, a sphere has to literally expand. So unless it's made of rubber it's a good shape for a pressure container that doesn't propagate sound waves to the outside. And when the wavelengths are long compared to the enclosure the internal shape doesn't matter much.
Old 14th December 2012, 03:06 AM   #24
expert in tautology
bear's Avatar
Well, depending on the way the node is occuring, the sphere could deform out in one or two axis while in on the other, and oscillate like that, no net change in volume, just shape. Could. Think balloon. Just stiffer... or tennis ball when hit, viewed in slow motion.
I suppose that a sphere internally will focus waves hitting the wall, but they won't stop there... they'll be reformed, perhaps with interference and sent back out... resonant nodes can still form.
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 14th December 2012, 05:29 AM   #25
Again, that's only true for higher freque ncies. And such a sphere should be tensioned with internal wires so it doesn't deform.
Old 14th December 2012, 05:36 AM   #26
Einric is offline Einric  United States
Einric's Avatar
I always figured on using a punching balloon, this way you could tailor your volume to your needs.
You could lay up 3/8" worth of fiberglass really easy and leave the balloon in tact as a sort of rubbery inner coating.
You could even pull the balloon at one end to make a teardrop shape if you wanted.
A continual curve layup of fiberglass 3/8" thick would be RIDICULOUSLY strong and light.
A bit itchy though I guess.
Old 14th December 2012, 09:28 PM   #27
pepsi's Avatar
_-_-bear
people keeping talking about standing waves being a problem. as far as i undersatnd, internal standing waves (which are waves canceling themselves out) are actually good when inside the enclosure. however, resonant nodes, like you mentioned would be problamatic.
Old 14th December 2012, 09:30 PM   #28
pepsi's Avatar
has anyone got access to any comparitive measurements of different internal enclosure shapes?
Old 14th December 2012, 10:13 PM   #29
expert in tautology
bear's Avatar
standing waves will produce resonant nodes and anti nodes by definition... afaik.
wires will vibrate and ring...
if you want a perfect enclosure you have two:
- anechoic chamber
- infinite baffle
_-_-bear
_-_-bear
Old 14th December 2012, 11:09 PM   #30
Standing waves cancel in some spots and reinforce in others, depending on whether you're at a node or anti-node. But indeed, a resonant point can become a 'trap' for that frequency (or a bit lower) when you stuff the space with absobent material. And for low frequencies the shape is irrelevant, it's just an air-spring tank.
Minimising standing waves GerhardW Multi-Way 13 2nd September 2008 08:43 PM
Standing waves, anyone willing to experiment ? jay1st Multi-Way 4 10th February 2008 02:33 AM
Standing waves again... Vikash Multi-Way 4 4th June 2004 12:25 AM
Golden ratios and standing waves Vikash Multi-Way 36 27th September 2003 03:12 AM
curved enclosures/standing waves RobWells Multi-Way 8 1st August 2003 03:28 AM
Copyright 1999-2017 diyAudio
