batteries in crossover, like JBL
Old 20th December 2009, 03:33 AM   #1
MisterTwister is offline MisterTwister  Tibet
Default batteries in crossover, like JBL
JBL is using 9v batteries in their Everest system. Can someone explain how to connect batteries to a crossover?
I don't expect any miracles from adding a battery, but still would like to try it.
Old 20th December 2009, 03:43 AM   #2
Robh3606 is offline Robh3606  United States
Robh3606's Avatar
What you do is this. You replace the existing capacitor with 2 capacitors that are double the originals value in series. That gives you the same value. At the node where the caps join you put a 2-3meg resistor. You take the other end of the resistor and attach it to the +9V of the battery the battery negative goes to ground.
You don't get miracles you get better low level resolution.
Rob
"I could be arguing in my spare time"
Old 20th December 2009, 03:56 AM   #3
Thank you
Old 20th December 2009, 05:03 AM   #4
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
There are at least a couple pages in the Elsinore thread about this.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th December 2009, 11:15 AM   #5
tvrgeek is offline tvrgeek  United States
I thought this was put to bed a long time ago?
batteries in crossover, like JBLHide this!Advertise here!
Crossover for JBL 4311-4312 series? ole Multi-Way 9 24th February 2010 10:42 AM
JBL 2225J& 2445J Crossover skybird Multi-Way 0 10th August 2009 05:22 PM
FS: Edgarhorn 300hz horns, JBL LE5-2's, and Lambda TD15M & crossover parts Rescue Toaster Swap Meet 2 3rd January 2007 04:34 PM
JBL 4412a with active crossover ckhaing Multi-Way 0 3rd January 2007 09:46 AM
Need Crossover layout for JBL Ti10K Jan De Smet Multi-Way 1 1st February 2004 08:05 PM
Copyright ©1999-2017 diyAudio
