Old 20th December 2009, 01:51 AM   #1
Default midbass - 3" 2 layer or 2" 4 layer?
I was just thinking about advantages of 4 layer voice coils.
In pro audio normally 2 layer aluminum voice coils are used to reduce weight.
If a 3" 2 layer aluminum voice coil speaker will hv 99 db spl level. Then considering all other items/factors same, then 2" 4 layer copper voice coil will also hv same spl 99 db.
But the .qts will be low & BL will be high for 4 layer voice 2" voice coil. Total weight will be little high for 2" 4 layer say 10%.
which will perform better for midbass application.
Old 20th December 2009, 09:01 AM   #2
chris661's Avatar
The 3" 2 layer will get rid of heat far quicker - the extra area would mean overheating is much more difficult.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 20th December 2009, 10:53 AM   #3
Yes u r right.But the wire guage will also be thin in 3" 2 layer..
To reduce the the heat we can put copper ring on T yoke.So heat effect will be taken care of. The Le also will be reduced to get better high frequency response.
Pickle or pitch layer rinx Multi-Way 7 22nd May 2008 02:40 AM
Constrained layer damping / thin metal / fibreglass layer RobWells Multi-Way 3 6th August 2007 05:50 AM
Does anybody know this kind of damping layer? vubkevin Multi-Way 5 1st August 2007 12:48 AM
single layer djronbxs Everything Else 0 15th January 2007 06:52 PM
double layer capacitors zx3chris Parts 3 9th April 2003 01:18 PM
Page generated in 0.07237 seconds (69.78% PHP - 30.22% MySQL) with 10 queries
