Old 15th December 2009, 02:51 PM   #1
Default 8"+1" combo home use
Hi all.
My Klipsch LaScala/Belle clone project has to wait (have a new job in NL/amsterdam, a lot of traveling and no space), but keeping in touch with greg (mid/high horn combo).
So I came up with an idea to build a small speaker using cheap pro drivers (higher efficiency) to drive them with some cheap tube amp.
Drivers used should be Beyma SM108, B&C DE10 (ME10 or XT120)
attached are sketch ups.
My Qs are:
-any good CNC wood cutting near Amsterdam? (considering I dont have to provide wood, just drawings)
-any good source for the drivers in Netherland?
also would like to hear your suggestions (critics welcome)
Danny
Old 15th December 2009, 07:21 PM   #2
nobody? ;(
Old 16th December 2009, 03:16 AM   #3
blue934 is offline blue934  Canada
sorry i can't be of help with this design but i hope you can make it work. i have been interested in building a hifi set with pro drivers to hear what they sound like but all the designs i see use 12 or 15" drivers and i don't want anything that big. your 8"+1" looks just right for me.
david
Old 16th December 2009, 04:22 AM   #4
Brett's Avatar
The SM108 is almost textbook for a B4 alignment: 11.3L net, f3=69Hz. You can work out the port.
ME10 works well with the DE25 for about a 2k xover, but unsure of the DE10. I also like the XT120.
You are still going to need to design a xver for it.
Re wood: do as I do and go to a kitchen maker with a large accurate table saw and get them to cut it. Usually doesn't cost much.
Old 16th December 2009, 07:37 AM   #5
brett thanks.Perhaps I can consider another 8" driver, because I have something like 25-27L net volume (driver, port, bracing already deducted).
Any suggestions? I'd like to get the driver down to cca 60Hz, at least, with some EQ, so the driver has to have a bigger xmax .
I've been considering a B&C 8NDL51,a little bit expensive for what i want, but good xmax.
david, my design goal is more like dynamics, and high power level.And portability I dont want a speaker that weights 150kg when I'm abroad. I want to use activ Xover.
danny
Old 16th December 2009, 11:39 AM   #6
sumacSK is offline sumacSK  Slovakia
Send a message via ICQ to sumacSK
Ahoj
RCF L8S800 should by good.. http://www.prodance.cz/protokoly/RCF_L18S800.pdf
emi beta 8 is ok if you want to keep it cheap..
if you have 25L volume you can also consider 10"...
Old 16th December 2009, 11:56 AM   #7
nazdarek sumacSK
yes i want to keep it cheap, i have another ongoing project at home which is very expensive to me.10" is to big.
I dont know about the eminence beta8, but i like the idea of beyma sm108.
I've modeled it in WinISD with linkwitz transform circuit, and taken down to 50Hz in 23L closed box, it showed that i wont reach the Xmax. but perhaps i'm doing something wrong also the sensitivity was around 94dB ...
can somebody model this driver in a different program if he get the same? i'm little bit confused. anyway, i will be ordering the drivers after new year holiday.
danny
Old 16th December 2009, 03:33 PM   #8
CCU is offline CCU  Denmark
Send a message via MSN to CCU
here's a good source for drivers and i THINK that they are from the Netherlands
EUROPE AUDIO - Home page
Old 16th December 2009, 03:55 PM   #9
Godzilla's Avatar
I like these two designs. Thanks for posting them to get our creative juices flowing. Can anyone comment on which sounds better in a simple two way like this, the Beta 8 or the Alpha 8 in a home stereo application. Is it possible to use these drivers without crossover and just blend an appropriate tweeter? They seem to roll off nicely on top.
TIA!
Godzilla
Old 16th December 2009, 08:17 PM   #10
Hi Godzilla!
I've actualy chosen the Beyma SM108.
But a lot of guys mentioning the Eminence drivers.Isn't the Beyma a class better?
danny
Mark's proto 6.5" Woofer, 1" silk Tweet combo markaudio Markaudio 251 25th April 2012 04:07 AM
FS: Seas Excel TL Home Towers "Thors" Houston/Austin pickup only kappa546 Swap Meet 15 1st September 2008 03:12 PM
What's the difference between CD Car Headunit and CD Home Player "line output" ? calico88 Solid State 1 1st August 2008 09:54 AM
Bash Sony's New "Micro Home Theater" ak_47_boy Everything Else 3 28th May 2007 10:37 AM
How to unjam a DVD in Sony "Home Theater" DAV-C450 amosslee Everything Else 0 5th July 2006 08:27 AM
Page generated in 0.09572 seconds (84.20% PHP - 15.80% MySQL) with 11 queries
