I seem to remember this being asked and answered a while back, but I just can't find it with Search, so...
Can I move the port on Martin King's FE164 ML TQWT design from the front to the rear with no other changes?
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#2 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
Thanks Dave,
I prefer the aesthetics of port in the back myself. Does the base slab weight or density have a significant impact on sound? I haven't cut pieces yet, and can cut them out of either 1" or 3/4" MDF, or even other things like cheap pine or cheap plywood if acceptable.
#4 |
frugal-phile(tm)
Mostly building out of plywood these days, and the speakers tend to be tall, skinny, & top-heavy (where the drivers are). So the prime purpose of the base is to get a little wider footprint. Using something with some mass is also useful in helping them from tipping. With the bipoles we build, rocking from the speaker moving in and out is not an issue, but it could be with a box with front firing only speakers.
Aesthetically we like the base offset from the speakers with copper pipe, so when we need it we put the port on the bottom. dave
#5 |
is there any difference in sound quality between a front port and a back port? (not only for TL ports, BR too)
#6 | |
frugal-phile(tm)
dave
#7 |
and with no HF garbage, is there any difference in sound quality?
#8 |
It's down to taste, some people like it direct, (front), some like it diffuse, (rear).
A rear port can also minimise the chuffing sound of a box or port worked too hard.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
| Slot port vs circular port equivalence | Brisso57 | Multi-Way | 12 | 21st February 2009 02:38 PM |
| Single Port Vent Better than Dual Port? | Daveis | Multi-Way | 18 | 15th July 2007 05:12 AM |
| To port or not to port? Newbie with newly built mains | starquake | Multi-Way | 1 | 18th December 2004 12:51 PM |
| Size and position of the port in a ML TQWT | teodorom | Multi-Way | 3 | 12th June 2004 01:57 PM |
| ML-TQWT port direction : down/forward? | Jim McPherson | Multi-Way | 4 | 2nd June 2004 09:14 PM |
