Old 14th December 2009, 08:40 PM   #1
Send a message via AIM to Spasticteapot
Default Advice on boxes and xover for W18EX001?
I have some Seas Excel W18EX001 drivers I'd like to use, and was hoping people could answer some questions I have.
1. I'm hoping to use one of these drivers per speaker in some small (~14 liter) sealed boxes, crossed over around 60hz to a small subwoofer. I'm aware that thiele-small parameters are all wrong, causing an impedance issue. However, these speakers will be used with an active crossover and bi-amped, and WinISD shows a nice smooth rolloff for the W18EX in the box I intend to use.
2. I'd like to use these woofers with some ScanSpeak 6600 tweeters. While this is not an entirely optimal configuration, I hope to use a waveguide to boost the low-end efficiency of the tweeter to allow for a lower xover point. Assuming I make use of the very high order (6th+) filters made possible by the DCX2496, how high can I cross this woofer over? I was thinking 1.7khz, but 1.5khz should not be a problem.
Old 14th December 2009, 09:27 PM   #2
Unibox shows that 14L sealed will give you an F3 of 116, and recommends 4L for an F3 of 99Hz, either way you'll have a gap if your sub crosses at 60 Hz. Personally, I'd do without the sub and go vented; 16L tuned to 43Hz gives an F3 of 43Hz.
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 14th December 2009, 11:23 PM   #3
D'oh! You're right!
Looks like I'll have to swap 'em for some W18E001s.
Old 15th December 2009, 07:40 AM   #4
The woofer looks ok, but what I do not like with these Excell drivers is the breakup node which is hard to control and even with a steep xover and a notch - you can still hear it occurs. However, I think that this driver can be smoothed with some modifications to the cone.
If you use waveguides to the tweeters, you can cross them lower, they will be easy to align with the woofer and they will need less power. The waveguide should cause a roll off at the high treble of the tweeter.
www.mariopankov.com
Old 15th December 2009, 08:09 AM   #5
StigErik's Avatar
Its best to cross over those drivers no higher than 1 kHz, that's where you'll start to hear the effects of the cone breakup. I'd rather swap them for 8" Excel W22EX001, which have the same breakup frequency, but lower distortion and higher max SPL.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
HU's - AMP's and Xovers , noob needs Xover advice metaverse Car Audio 5 22nd January 2009 05:15 AM
wtb seas w18ex001 dagney2000 Swap Meet 1 11th March 2008 04:29 AM
WTB: Seas W18EX001 Seth Smith Swap Meet 1 19th January 2008 12:53 PM
Xover advice for first 3way project silvercans Multi-Way 1 29th October 2005 11:56 AM
Page generated in 0.07219 seconds (74.25% PHP - 25.75% MySQL) with 10 queries
