Any of you guys have a clue what is an effect of using No Baffle (magnet mounting) is to Baffle Step.
Edge does not simulate it properly. Would Baffle Step depend on how much of a driver is outside of membrane (if you know what I mean) ? Very narrow baffle results in quite a peak at about 500hz wich is too high for me. I can stay with 18" wide baffle compromising precise imaging or mount speakers (Saba Alnico) by their magnets. |
#2 |
#3 |
EDGE can do this... Set # of corners to a high number (like 100), then you get a round baffle. Set the size to the same as the frame (or slightly larger), and driver size to the diameter of the cone.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles |
#4 |
StigErik:
Already did it, but when I drag the speaker out of the baffle results are different then when fit into very,very small baffle. |
| Does open baffle suffer from baffle step? | 454Casull | Multi-Way | 15 | 19th May 2012 03:12 PM |
| Baffle Step question | mazeroth | Multi-Way | 12 | 24th January 2006 10:45 PM |
| baffle Step | rgrayton | Full Range | 33 | 4th December 2004 11:16 PM |
| Baffle Step + Sub | Aural Dan | Multi-Way | 7 | 9th October 2004 08:23 PM |
| baffle step help. | AudioGeek | Multi-Way | 3 | 10th February 2004 11:02 AM |
| Page generated in 0.07361 seconds (70.89% PHP - 29.11% MySQL) with 10 queries |
