I am about to embark on my first speaker project with components that I have acquired over the years.
My goal is to build a home theater speaker package that will out perform most put together packages found at your average consumer electronics store. I am looking for advice on what to do with and where to use my components. OK here are some of the components. Infinity RS-1 8 inch driver. 5 of them. ![]() ![]() Dayton 12 inch driver 4 ohm accordion surround. Don't have much info on them. I have two of these. ![]() ![]() Here is what I was thinking.... Use one 8 inch driver in 5 channels or 2 8 inch drivers in each of the front channels and one in the center channel while coming up with some 6 1/2 drivers for the rear channels? My reason for coming up with option 2 is that maybe 8 inch drivers for surround cabinets is a little overkill? Or do you guys think it will be fine with having matched drivers all around? Next there is the sub woofer. I do not have much info on the 2 Dayton's I have. I wonder if they would make good sub woofers in a home theater setup because of there limited excursion due to them having an accordion surround. If the wont work for me no worries I will build another sub woofer. So there you have it. Give me some input guys |
#2 |
Did I post this in the wrong forum?
#3 |
Speakerholic
Right forum but we will need you to dig up some info on the drivers first. ie: T/S parameters. Without them it's a bit of a crap shoot. Having all five drivers for the 5.1 system is a good idea. They can always be rotated if you feel the rears are being used less than the fronts. That Dayton unit looks to be a PA driver so you won't get much extension of the low end. It's meant more for music than HT I think. |
#5 |
Dayton 121399. I think thats it. There is a decal on the side of the magnet.
This is all the info I can dig up on the RS-1 drivers http://www.infinity-classics.de/infi...ical_sheet.pdf |
#6 |
Speakerholic
Dayton drivers start with letters. That looks like a cone number you have given us. I don't see any current offerings that match those. What size are they and approx how old?
#7 |
Dayton looks like Eminence, but no surprice
Dayton is usually through PartsExpress, or ? Looks like theres very small spider, which could indicate a pro midrange driver Last edited by tinitus; 14th December 2009 at 05:21 PM. |
#8 |
There were some Eminence 12s that looked like that, I think. Hmmm....
Anyhow, you really ought to measure them. That's the best way to go.
Take the Speaker Voltage Test! |
#9 |
The only letters on this driver are G2. It's a 12 inch 4 ohm driver.
#10 |
Speakerholic
Have a look at Parts Express site and see how the Dayton units use letters that give a hint as to what type of driver they are.
| JBL 2416H 1 inch HF Drivers | imix500 | Swap Meet | 0 | 16th July 2009 02:47 AM |
| Best 10 inch sub drivers for sealed enclosure | brox | Subwoofers | 17 | 14th March 2007 07:40 AM |
| 18 inch pa drivers WANTED min 400w rms. | Bull | Swap Meet | 3 | 12th February 2006 07:35 AM |
| Best 4.5 inch drivers? | jazzbearz | Multi-Way | 8 | 17th January 2005 11:40 PM |
| Four 8 inch drivers waiting to be used | cm961 | Multi-Way | 16 | 8th July 2003 07:08 AM |
| Page generated in 0.09817 seconds (78.47% PHP - 21.53% MySQL) with 10 queries |
