Hello everybody
how are you? I have to do an assignment ind submit it next friday, so I've got some question about it. if you don't mind can help me pls 1- how many type of it? 2- what is the main point can i add it to my research? 3- physical and mechanical properties of the device? 4- hoe it is boxed? that's it thank you> |
#2 |
2", 3", 4", 5", 6", 7", 8", 10", 12", 15"
Thats the CONE speakers come on fellows, its a fun challenge His challenge is to make sense of the mess coming Lets bombard him with the mess
#3 |
Absolutely flush mounting in a concrete box.
Extremely low mass and powerful motor associated. Better if used in a 10+ array , obviously each speaker driven by its amplifier ; the drivers and the amplifiers should be computer matched (+- 1% max). When building it , rice paper must be soaked in rose water in a calm night . |
#4 |
thanxxxxxxx but what about the another questions?????????????????
#5 |
dont forget to permanently attach a truck dolly to concrete cabinet for easy moving
#6 |
An electrostatic is what you want to report about.
#7 | |
2. What you call a "point can" is usually called a phase plug. 3. Solid; in and out. 4. Above the belt.
"Part of the reason a poot into a toilet bowl sounds the way it does is because of phase shift." -Andrew Eckhardt |
#8 |
"Eye of newt, and toe of frog,
Wool of bat, and tongue of dog, Adder's fork, and blind-worm's sting, Lizard's leg, and howlet's wing,-- For a charm of powerful trouble, Like a hell-broth boil and bubble." |
#9 |
oops, sorry Khalef,
because you are so close to Stratford-upon-Avon and as 3ways are so extremely difficult, I just couldn't resist! best wishes for your assignment. |
#10 |
just a start:
Mid-range speaker - Wikipedia, the free encyclopedia |
| DIY loudspeaker vs. factory built loudspeaker | keyser | Multi-Way | 83 | 16th May 2011 12:27 PM |
| Frequency range of the human voice & full range center channel speakers | jwmbro | Multi-Way | 31 | 20th January 2008 03:07 PM |
| SNR/Dynamic range worsens in low frequency range. | percy | Digital Source | 3 | 1st June 2006 12:41 PM |
| what makes a loudspeaker "full range"? | kneadle | Full Range | 25 | 15th April 2005 07:53 PM |
| Page generated in 0.10265 seconds (80.70% PHP - 19.30% MySQL) with 10 queries |
