I ask as speaker cones move air, and so do fans.
I'm bi-amping, and am putting the amp module within the speaker box. I guess they'll be active speakers now. I've upgraded the heatsink on my amp but it still gets a little hot... Would putting a low speed fan on the heatsink affect the sound from the speaker in any way? The speaker boxes are simple reflex designs, FWIW. |
#2 |
Wouldn't it be easier/better just to keep the amps outside of the box?
The small (compared to the room the speakers are in) amount of air inside the box is already being heated up by the voice coils (which in itself leads to the dreaded power compression) and adding amps on the inside can only make things worse, nevermind any fans. If the fan would be aimed to exhaust through the reflex port I can well imagine that it might change the resonance with further detrimental effects. If the fan is NOT aimed to exhaust through the port I fail to see any advantage of having it at all in the long run (ie if you run the speakers at volume for a while) as it would just end up circulating already hot/warm air. |
#4 |
If you want to put the amp module in the box, please let the heatsink out of the box.
| 7.1 digital speaker idea | GestaltH | Digital Source | 2 | 2nd January 2011 11:54 PM |
| speaker grill idea | gychang | Full Range | 3 | 31st October 2008 10:32 PM |
| Crazy speaker idea | crick | Full Range | 0 | 22nd August 2007 12:03 AM |
| PC Speaker System (2.1) Idea Help | AIA | Multi-Way | 4 | 15th October 2006 02:22 AM |
| Speaker idea: best of both worlds | Nielsio | Multi-Way | 12 | 30th November 2002 06:12 AM |
| Page generated in 0.07602 seconds (75.00% PHP - 25.00% MySQL) with 10 queries |
