Anyone Built Seas Thor TL ?
Just a stupid question..hehe..
I'v got some spare money..and I might be thinking about building my own speakers. (looks like a nice experience)
The main reason is the fact that my B&W206.5..don't have a low enough mid range..I dunno..it feels as if there is a gap in between my sub and my speakers..
Now I just checked up on those Thors..and I see they sell the speakers for 742euro's :cannotbe:
Am I supposed to search for all the part for the corssover myself?
And the wood? (smaller problem)
I just don't have the faintest clue as to how much this joke is going to cost me..hehe
So..it comes down to this..how much did you pay for the crossover parts and the wood? (and where are you from, cause these things are cheaper in certain parts of the world)
I live in Belgium..
Bafke
when you post a pic.
when you repply you will see under the screen where you fill in your test youll see attach file then browse browse to the pic you want to post..
Andrew01
Hi Andrew,
My thought is you would want to have the speakers out from the wall an amount, but you'd also probably want to know how much baffle-step correction that the system was designed with, in order to know how much to space them out. Further, I don't recall if the speaker was designed with the output of the port in mind, in its relation to the amplitude of what the driver is doing, to ensure that it doesn't over-power what comes from the driver. The port being at the rear, being supported by the rear wall (or not depending on how far the system is from the wall), has some bearing on this, plus the amount of stuffing that you use. It depends on how much you care about this, really.
So, you'd want to space it out from the wall an amount, say 6 to 12" just for the sake of letting the line breathe, but I think the issue goes deeper than this.
One thought that Planet10 had on this design is to increase the amount of taper, to tune to the line to a lower frequency. I completely agree with this, however, I would probably re-design the line to have the terminus at the floor, but that's just my re-thought.
You may want to get the article that Joe d'Appolito wrote in AudioXpress May 2002.
Hope this helps,
Brendon
BrianGT said:
No veneer on the speakers. I used oak plywood on the sides and solid oak on the front, rear and back.
Here is the correct link for the gallery:
http://brian.darg.net/thor
Brian
OK, do you didn't have problems with veneering
Do you have an idea about how I could veneer a cabinet that has all the four edges rounded?
PS: I plan to build a pair of peerless pipes, I know you also built a pair. What amp are you using with them? Since they're only 84dB/W/m , I don't know if my gainclone will be enough 🙁
As far as veneering goes, I have never done it.
The peerless pipes are still just a pile of wood sitting in the corner, and a box of drivers and crossover components. I am going to start assembling soon, as I am finally finishing up other projects.
Brian
On a side note, you motivated me to start building to peerless pipes tonight. Thanks!
I will post my progress here:
http://brian.darg.net/peerlesstl
If you are interested...
biscuits, wood glue and lots of clamps make me happy 😀
(20 clamps, mostly borrowed, used in the below pic)
Brian
