Hi all, another almost dumb query.
I need some high value inductors for my rebuild of my party speakers, going passive rather than active. I have some laminate core inductors from local firm Jaycar here and I want to raise inductance from 5.6mH to as high as possible but also as cheaply as possible. I have purchased 2 small rolls of 1.25mm wire from the Geelong Jaycar store, 100 grams each. There is no point in calculating possible improvement, I'll wind and then measure; BUT : what is the best way to join the 2 lengths of wire together given that they are of 2 different diameters?? 1mm>2 // 1.25mm>2
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#2 |
Personally I'd take avantage of the varying dia. and butt them up end to end. It won't be easy but it certainly gives you the best shot at a clean joint, and a resulting smooth winding.
#3 | |
Take them out, and connect them after winding Gives you more options I made this toroid that way, and have a cap/res(zobel) mounted on connecting midpoint |
#4 |
OK Tinitus
Picture is worth a 1000words! Good thinking, I'll do it that way, gives me extra options. thanx, well worth the asking
| Adding extra magnet | jamikl | Multi-Way | 16 | 30th January 2009 02:47 AM |
| Rewind on existing voice coil | Datubie | Multi-Way | 0 | 3rd November 2008 11:58 PM |
| Adding an extra magnet | ding | Multi-Way | 8 | 14th October 2003 04:57 PM |
| Adding a DC-Servo to an Existing Amp | EchoWars | Solid State | 14 | 7th October 2003 10:31 PM |
| Adding a side firing sub to an existing speaker? | mikejz84 | Multi-Way | 4 | 24th June 2003 09:07 AM |
| Page generated in 0.08191 seconds (65.66% PHP - 34.34% MySQL) with 11 queries |
