Old 9th December 2009, 07:41 PM   #1
MCPete is offline MCPete  United States
Default Where to measure max. input voltage to woofer
This is all about experimentally testing Small's formulation that
Per = Par/ No
where
Per = displacement-limited (maximum) power
Par = displacement-limited acoustic power rating
No = eta or efficiency
Small also defines Pe as input electrical power where the impedance of a driver is considered to be the dc resistance of the driver Re. Then
Vi(max) = sqrt(Per*Re)
where Vi(max) is the rms voltage at input to the driver causing diaphragm displacement of the driver to equal Xmax.
So let's say that I have a two-way closed-box system with a passive crossover network. I'll measure the peak displacement of the woofer's cone of the system when electrical power at input is that which should cause that displacement to equal Xmax. The input signal will be pink noise as pink noise has power density distribution that is roughly equivalent to that of music.
My question is, should I measure Vi(max) at the input terminals to the speaker system or across the voice coil terminations of the woofer? As there is the low-pass filter between the system input terminals and the voice coil of the woofer, these two voltages will be substantially different.
Sorry about thinking up this stuff. Have a great day.
How to measure Common Mode Signals in the input stage? Pippi Lindenstroem Solid State 4 16th October 2009 03:36 AM
Sub-woofer high level input StalfoS Solid State 2 15th February 2007 11:00 PM
Input voltage lpd Tubes / Valves 2 11th July 2006 05:49 PM
How To Measure Input Impedance Of Solid State Amplifier? kelticwizard Solid State 11 28th January 2006 03:34 PM
Input voltage seahag Chip Amps 4 30th November 2004 03:34 PM
Page generated in 0.07299 seconds (66.29% PHP - 33.71% MySQL) with 10 queries
