Old 8th December 2009, 10:06 PM   #1
badman is offline badman  United States
Custom Title
badman's Avatar
Default Selenium HM17-25
Selenium HM17-25
The Datasheet
Interesting horn, this Selenium. It looks like a nice, cheap way of getting a smoothly terminated horn without a diffraction slot, basically an adapted JBL 2404 with the dispersion characteristic traded for smoother throat contouring. I've not seen these used in any projects, but have ordered a quad for testing (I plan to hack 2 of them to get the driver mounting piece for use in DIY OS waveguides).
Anyone have any thoughts on this itty-bitty bi-radial? With a little care, it looks to be a very good candidate for a geddes-styled 2-way with a 12", XO at 2.5k.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 9th December 2009, 12:30 PM   #2
Maybe this you will find helpful. Polars per 10deg, 1/3oct smoothed. No idea about any 12" reaching 2K5 without serious break-up issues.
Tomas
Old 9th December 2009, 01:42 PM   #3
Inductor's Avatar
The horn is problematic in the back (to be airtight) against the box. Not a flat surface. I'm using it in a 3-way.
Old 9th December 2009, 01:58 PM   #4
wg_ski is offline wg_ski  United States
The 17-25 sounds really nice in the horizontal plane. Go up or down, and it goes south in a hurry. The 25-25 metal horn degrades a bit more gracefully on the vertical axis, but won't get up as high regardless of the driver used.
In either case, they work better paired with 10's than 12's when crossed at 2-2.5k.
Wolf (from the PE board) has used the 17-25 and thought well enough of them to pair them with some really expensive Morel midranges. I think he used the cheap Selenium driver, too.
Old 9th December 2009, 02:57 PM   #5
Pano is offline Pano  United States
Pano's Avatar
I've had these for years. Driven with the Selem D210Ti. Not bad.
Strange frequency response at the top, but that may be the driver.
I did modify mine a little. I filed down the ridge in the throat at the start of the horn flare. Removed the bug screens from the driver. Used putty to fill the gap between the horn throat and the the driver throat. As mine don't screw all the way in, there is a nasty gap.
Guess I should post before and after measurements to see if there is any merit to my mods.
Take the Speaker Voltage Test!
Old 9th December 2009, 04:48 PM   #6
Custom Title
badman's Avatar
Wow, yes, that's extremely helpful! Very nice polars. Looks like 1k5 IS a viable crossover target, assuming a very steep applied slope. I was thinking 2k5 as I was assuming such a small horn to have very limited pattern control at the lower end, looks like the tight pattern works better than I thought.
It would indeed be interesting to see your before and after, pano. I'm enthusiastic about trying this horn now
Old 9th December 2009, 09:57 PM   #7
Pano's Avatar
I'll do some after mod FR plots then.
No idea if I did any good.
Old 10th December 2009, 08:56 AM   #8
Originally Posted by badman View Post
Wow, yes, that's extremely helpful! Very nice polars. Looks like 1k5 IS a viable crossover target, assuming a very steep applied slope. I was thinking 2k5 as I was assuming such a small horn to have very limited pattern control at the lower end, looks like the tight pattern works better than I thougt.
It is smaller because it relies on edge diffraction. Take care, polars are 1/3oct. smoothed, so don't expect world-class performance.
Tomas
Old 15th December 2009, 12:13 AM   #9
Custom Title
badman's Avatar
It doesn't seem to have any throat roughness in the examples I have here, which is BONUS!
Old 15th December 2009, 02:14 AM   #10
Custom Title
badman's Avatar
That ridge seems to have likely been an apparent ridge, if the ones I have are any indication- apparent in that it was there because of the gap between driver and horn.
Amp for Selenium's 18SW1P asnn Solid State 5 8th January 2009 10:49 PM
NOS Selenium Rectifiers Zero Cool Swap Meet 1 5th October 2008 02:45 PM
Selenium D4400ti tadman Pass Labs 0 25th February 2004 09:25 AM
Selenium 3300TI Jer Multi-Way 1 27th November 2003 12:51 AM
What does a selenium rectifier do? Newpaltzwonder Everything Else 7 15th April 2003 12:27 PM
Page generated in 0.12736 seconds (80.82% PHP - 19.18% MySQL) with 11 queries
