Old 5th December 2009, 03:19 PM   #1
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Default MTM, Two woofer formula?
I want to design an MTM "tower" with two 15" drivers & a horn in the middle ala DeAppolito type.
I came across this driver, 15",Fs=42Hz,Vas=8.6cu FT, Qms=4.73, Qes=.44, Qts=.4, Db=101.6 @1W1M,
I ran the formulas & came up with Vb=9.3004...., F3=39.385...., Fb=40.238....
The thing I don't have is the formulas for twin drivers in a tuned box.
Is there a hard formula for dual/multiple drivers?
The application is for a very low powered tube amp......I'm shooting for 104+ Db response. I know it can be done, I've just come to this impasse.
__________________________________________________ _________Rick......
Old 5th December 2009, 03:37 PM   #2
Did it Himself
richie00boy's Avatar
Just double box volume and use two ports as they would be in a single box.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 5th December 2009, 03:44 PM   #3
infinia is offline infinia  United States
infinia's Avatar
You can use the same formula for 2 identical drivers using T/S for the single, with the only difference being Vas is doubled. Your tuning of Vb~1/2(2*Vas) is about right for the double.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 5th December 2009, 04:32 PM   #4
Scottmoose's Avatar
For modelling purposes, if the twin drivers in parallel, Sd & Vas effectively double compared to the single unit, while Re & Le are halved. If the twin drivers are wired in series, then Sd, Vas, B*L, Re & Le all nominally double compared to the single unit.
formula help paba Tubes / Valves 6 1st December 2009 02:37 AM
box formula crs1 Multi-Way 29 23rd January 2008 09:53 AM
Q formula PeteMcK Multi-Way 10 17th January 2008 07:42 PM
Need help on x-over formula Jay Multi-Way 3 12th August 2003 05:28 PM
Anyone have the formula for... Rino odorico Multi-Way 4 22nd January 2003 04:07 PM
Page generated in 0.07722 seconds (68.69% PHP - 31.31% MySQL) with 10 queries
