#2 |
Nice!
Do you take commissions? |
#3 |
Nice work, we hope to see more!
Take the Speaker Voltage Test! |
#4 |
Thanks for the compliments. No commissions (yet) That was the first one I have ever made. I will probably start a build thread soon as I almost have all the MDF cut. 2 way bi-amped with automotive based A/D/S 320is woofer and Alpine 6022 tweet. Flame maple front w/ black finish elsewhere. After that will be a 4 channel LM3886 Gainclone project.
#5 |
Very neat! How big an OD to you think you could make?
#6 |
This is the max. 4.50". That is all my small lathe can handle at the moment. Though, the MFG. (Taig) does make a kit that raises the head stock 1" which would give a total of 2" more DIA. (6.5")
#7 |
I will probably make the second one this evening and will take some more pics of the process. Right now, it already has the OD turned and the center bored. I'll describe the details of that when I post the pics.
#8 |
How did you make the jig? Lathe also?
Soft Dome |
#9 |
Wood lathe is quite old
When doing large items it was usual to use the outside of the lathe, and have a stand on the floor, to support hands and cutting tool But this can be pretty dangerous stuff if doing it wrong Even if not doing it by hand but using metal lathe and fixed tools, it can go pretty bad if not secured properly |
#10 |
Yes, I made the jig on the lathe also. With the help of a band saw to get the rough circle on the plate.
The lathe is a small metal turning lathe. I hold the piece on with 3 #4 screws that are 3/4" long. It turns true (to within a few thousands of an inch) and is balanced well with no discernible vibration. I had zero issues turning the first one. With one bigger cuts than I am making, and that MDF cuts easily, those 3 screws should be plenty. |
| Baluster turning/lathe in Washington DC Area? | dgoodier | Everything Else | 0 | 8th August 2009 12:49 AM |
| need info about LP lathe etcher | inertial | Analogue Source | 12 | 31st January 2009 10:05 AM |
| Tooling (lathe / mill) recommendations ? | ckniker | Analog Line Level | 1 | 18th August 2007 06:20 AM |
| CD Lathe | soongsc | Everything Else | 10 | 28th October 2005 06:00 PM |
| MDF on a lathe? | masterp2 | Multi-Way | 20 | 29th January 2004 12:30 PM |
| Page generated in 0.11291 seconds (71.98% PHP - 28.02% MySQL) with 10 queries |
