I'm planning on using a compression driver mounted directly to the speaker baffle. Only problem I have is; once ive cut the throat in the baffle, whats the best way to mount the CD onto the baffle with good precision?
Any suggestion?
#2 |
what type of compression driver?
screw mount or bolt on?
...sword and pistol by his side. |
#3 |
#4 |
For example; how is this driver mounted to the horn?
#5 |
there are probably nuts recessed in the back of the horn that are held in place by the flat steel(aluminum?) ring and then the bolts go through the driver into those nuts.
#6 |
Its first mounted on a plate bigger than driver
Then monted on horn The final mounting screws are visible in your own picture Maybe it helps to look at driver below The rest is handywork Ofcourse there are ways to ensure a fast and correct allignment, but its complicated, and its just as demanding the first time But you can also do something like in drawing Last edited by tinitus; 5th December 2009 at 01:18 AM. |
#7 |
Seems likely, but how do you mount the bolts to the driver/t-nuts when both elements are stuck? Kinda hard to explain what I mean...
#8 |
#9 |
Well, they are PRO drivers, and such horns are usually different
btw, I added a drawing with alternative mounting in my previous post |
| Need suggestions for full size enclosure (rack mount ok) | maurycy | Parts | 2 | 21st November 2008 06:20 PM |
| Open baffle suggestions | AJ | Multi-Way | 83 | 20th January 2008 12:40 AM |
| Open Baffle Suited Woofer Suggestions | Tenson | Multi-Way | 34 | 14th March 2006 03:29 AM |
| Suggestions for Open Baffle Driver | dsavitsk | Full Range | 30 | 21st February 2006 06:54 PM |
| Page generated in 0.09077 seconds (85.41% PHP - 14.59% MySQL) with 11 queries |
