Old 3rd December 2009, 11:58 PM   #1
Default Please recomend an enclosure volume....
Hello gang, it’s been a while since my last post. I’ve been trying to work out the crossovers [tweeter attenuation] in my 3.5 DIY build. I think I’ve got them dialed in, but. I used the Peerless 832873 HDS 5-1/4" driver as my midrange and I’m troubled by it’s performance. They seem to play a little harsh around 4000 HZ, and I’m wondering if the [sealed] volume of the enclosure is the proper size.
My question is as follows: What [sealed] enclosure volume are you guys using / propose for the flattest frequency response with Peerless 832873 HDS 5-1/4" driver?
I look forward to hearing from you all!
Bill.
Old 4th December 2009, 12:16 AM   #2
Moondog55's Avatar
Bill I think it is more likely to be a crossover problem than a volume problem.
How much and what kind of stuffing is in the midrange box? I can't remember
Have you tried lowering the XO point to 3k at all?
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 4th December 2009, 12:35 AM   #3
Scratch 4000HZ I said 4000Hz because of the hearing damage in my left ear is around 4000Hz and when I listen to my CD player as a source, my left ear becomes irritated [not present with my turntable as my source]. The midrange band pass is set at a theoretical 300Hz - 3000Hz. I used a 8 ounces of Pollyfill in each midrange enclosure.
What do you think now?
Old 4th December 2009, 12:47 AM   #4
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
Cabinet size and port tuning should be the least of your worries when designing a speaker. You mention problems around 4kHz, this has little to do with your cabinet I suspect. Cabinet design dictates bass, and little beyond that. For a midrange, any smallish sealed cabinet should do, provided it's not a perfect cube, and has a decent amount of stuffing.
Have a look at Zaph's measurements for the 830882.
It's not your driver exactly, but quite similar. As you can see, there is 2nd harmonic distortion at 4kHz due to cone breakup. Being that it's 2nd order, it shouldn't sound too bad, but I would suspect it's noticeable. I would crossover a driver like this around 2.5kHz, 3kHz at most.
Can you share anything of your crossover design? Transfer function, etc?
[Edit: You replies as I was typing. Your cabinet is likely fine, if you're having troubles I would suspect crossover issues. Can you share further details on your speaker design?]
The power of Science compels you!
Old 4th December 2009, 01:24 AM   #5
The crossover is a 3 way second order DIY job. I used Jeff Bagby’s softare for the values. I did add Zobel correction networks [mounted to the crossover board]. The woofer is low passed @ 300Hz, the midrange is band passed @ 300HZ – 3000Hz and the tweeter is high passed @ 3000Hz. The .5 bass boost is not operable yet.
Bill.
Here is a pic.
Old 4th December 2009, 09:51 PM   #6
Francec is offline Francec  Australia
Banned
I've used the 832873 in an active speaker crossed at 300 and 3000 using an LR4 active low level crossover and they sound excellent. No harshness at all.
Frank
Old 4th December 2009, 10:45 PM   #7
Thanks for your reply!!! Please bear with me here, when you say "LR4", does that mean you used an "inductance & resistance fourth order crossover"?
Bill.
Old 4th December 2009, 11:04 PM   #8
Dave R is offline Dave R  United States
Dave R's Avatar
LR4 means "Linkwitz-Riley 4th order".
Linkwitz-Riley filter - Wikipedia, the free encyclopedia
This page has an example of a LR4 circuit (with a Zobel, Rz1 and Cz1 included on the Vifa Dual)
Speaker Workshop Project Crossover Design
- Dave R
the 200% Norske
Old 5th December 2009, 04:03 AM   #9
Banned
Thia is what I used:
Linkwitz-Riley Electronic Crossover
Frank
Old 6th December 2009, 05:49 AM   #10
Originally Posted by Francec View Post
This is what I used:
Frank
OK, I understand wich crossover you used. I'd like to know if you went sealed or ported with the Peerless and what volume enclosure you used?
Enclosure Volume Mat_89 Subwoofers 3 19th September 2006 10:27 AM
recomend a fostex driver and enclosure...plz... nerd of nerds Full Range 21 20th December 2004 01:41 AM
Enclosure Volume sonu Multi-Way 12 14th May 2004 09:38 AM
Sub: Volume of Enclosure with Amp bigkid Multi-Way 16 19th July 2003 06:12 AM
Enclosure Volume r_s_dhar Multi-Way 16 13th August 2002 06:24 AM
Page generated in 0.11688 seconds (80.10% PHP - 19.90% MySQL) with 11 queries
