I'm trying once again to get the hang of speaker design, and I was wondering if someone could help me understand the effect of a waveguide on baffle step. From what I understand, baffle step does some very undesirable things to frequency response: According to a piece of software called "The Edge", frequency response varies a great deal between about 1.5khz and 4khz for a 1" tweeter mounted 75mm from the top and left sides of a 250mm x 350mm box.
If what I understand is correct, the use of a waveguide will limit dispersion to the point that the baffle no longer affects tweeter response. If this is correct, it would be a huge benefit: when combined with the lower crossover point a waveguide allows, it would greatly smooth frequency response. Thanks! |
#2 |
From my little understanding of the topic. Baffle step, or the amount there of, is a result of the speaker's design/application.
A speaker with a thin baffle such as your 250mm located several feet off the back wall will suffer fully from baffle step. Where as, a speaker designed to be mounted to, or within a wall. Suffers very little to nothing at all. I believe a "waveguide" in Dr. Geddes's definition of the term, needs to be a minimum of 10"s in dia to be effective. |
| Does open baffle suffer from baffle step? | 454Casull | Multi-Way | 15 | 19th May 2012 03:12 PM |
| baffle step using a dbx260 | slr 5000 | Multi-Way | 0 | 5th November 2008 03:00 AM |
| baffle Step | rgrayton | Full Range | 33 | 4th December 2004 11:16 PM |
| Baffle Step + Sub | Aural Dan | Multi-Way | 7 | 9th October 2004 08:23 PM |
| baffle step help. | AudioGeek | Multi-Way | 3 | 10th February 2004 11:02 AM |
| Page generated in 0.07032 seconds (69.48% PHP - 30.52% MySQL) with 10 queries |
